Frost INSIDE! Should I Be Worried? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 04:56 PM   #16
Rewards Points: 1,092
Originally Posted by jagans View Post
Rigid foam against a firebox? I dont think that is a good idea. Rock-Wool or fiberglass, maybe.
Agreed. I assumed the firebox was just storage now. Rock wool if it is being used; I don't think it will hold water much. Read their web site.
Old 01-28-2013, 07:05 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
I ran the fireplace for a while with it sitting outside the hole and it was still very cool to the touch all around. In fact even the part where the heater is was cool, it only gets hot directly in front of the heater, when it's on. The fireplace is more for show than anything. Ended up going with the foam as realized it's already a tight fit as is so would not have room for batts and I'd still have to put a vapor barrier while the foam acts as one. Waiting for caulk to dry then I'll add the vapor barrier tape. I might be able to throw some fiberglass batts in the back though and I might be able to squish it against the sides if there's still some wiggle room.
I'll definitely keep an eye on it for the first time I turn it on though.
At least that's one cold source less to worry about. Only like R3 though but think the air seal is probably more important than anything in this case. The brick probably adds some R value too, very small, but some.
If ever I decide to get a gas fireplace there, then I'd probably have to redo that whole area.
edit: Taped up!
Now a fireplace that does not make my house colder... lol
Of course with my luck it warmed up quite a bit so I'll have to wait and see how good of a job I did when it gets cold again. It's 0 right now, imagine that.
some frost on edges of roof sheeting in Attic above garage. Also am getting frost on roofing nails. Sebo20 Roofing/Siding 3 01-20-2013 09:36 AM
Frost on a concrete wall. sbmfj Insulation 11 01-31-2012 11:14 AM
Attic Frost Attic Roofing/Siding 2 01-15-2011 10:19 AM
Chilly inside new construction home katiealbano Building & Construction 2 04-13-2010 11:16 AM
Attic Frost cougar01 Building & Construction 5 01-28-2009 08:33 AM
