Frost INSIDE! Should I Be Worried? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 08:47 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Frost INSIDE! Should I be worried?
Been in the -30's lately which is standard for this month, we just have not been seeing it much in the past few years due to global warming. Noticed this the other day, did not think much of it given all the windows are doing it too. It's just so cold, and I do have a humidifier.
But today I noticed under that area in the crawlspace while measuring for studs/drycore which I want to install:
Also noticed the whole wall is starting to get frost now upstairs! I have a fan blowing on there now in hopes I can just get it to evaporate off. This is going to cause mold...
I also noticed another location where it's pretty bad:
I've been wanting to finish my basement, but should I be worried about these problems first? If I insulate that wall, then I will be reducing the heat loss even more, thus it will REALLY freeze badly. Or will the fact that it's sealed prevent frost from forming in the first place? I plan to get it spray foamed after I stud the walls.
Old 01-23-2013, 09:00 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
To much humidity and not good air circulation.
Glass is just a replacement for a hole in a wall or roof that gets cold and allows condensation. Circulation of air will get the moisture back into the house and cause the preset humidifier to run at a proper level. Air leaks are an obvious sign of localized condensation and freezing. Also, highly conductive materials or pipes (vents, intakes) that can conduct cold air at times can be problem spots.
We only get down to -20F (although -40F could be possible without wind chill) and we got up to 10F today, so we are not as severe and we have a lot of thermal mass in our place to maintain long term humidity and temperature. On windows - aluminum mini-blinds are great at night to eliminate the radiant heat loss that all the fancy gas and films cannot eliminate and still allow circulation.
Dick
concretemasonry is offline   Reply With Quote
Old 01-24-2013, 01:42 PM   #3
Wire Chewer
Rewards Points: 90
So I should not have to worry, and I can just get that spray insulated and it should fix the issue?
Old 01-24-2013, 09:28 PM   #4
Davejss's Avatar
Rewards Points: 746
The global warming should take care of it. Just ask Mr.Gore.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
Dave Sal (02-02-2013)
Old 01-24-2013, 10:49 PM   #5
Wire Chewer
Rewards Points: 90
Actually we have been seeing the effects of global warming here over the years but for the first time since I bought this house we're getting our standard January weather. So for all I know, it's always done that, and probably explains why some of the cinder blocks are out of place. But as far as global warming goes, a couple weeks ago snow was melting. WTF is that witchcraft? We don't have as much snow as before either, which is probably why this cold weather is hitting harder. I should probably shovel snow against the house. Normally, it would naturally build up 4-5 feet all around.
Speaking of frost inside, I decided to pull out the fire place for kicks to see what they did behind there. Nothing!
I have a fan blowing on that now to vaporize the ice. What is the best way to insulate that? Can I just use ridgid foam, some kind of glue, and vapor barrier tape for the seams and call it a day? The fireplace that goes there is just an electric insert.
Old 01-25-2013, 01:09 AM   #6
Rewards Points: 1,092
Rigid foam inside, against the blocks, (taped), with an interior wall tight against it to hold it, fill w/ Roxul if you'd like to, and sheetrock it; air seal; reduce humidity if it is high; better windows. Options. Doing all is the best, imo, but it ain't my money to do it all.....
Old 01-25-2013, 06:38 AM   #7
Davejss's Avatar
Rewards Points: 746
Leprecons, unicorns, bigfoot, loch ness monster, easter bunny, global warming.....
Old 01-25-2013, 07:04 AM   #8
DIY staff
Rewards Points: 7,174
-30 C. = -22 F.
That's some intense cold----make a note of all frosted areas for air sealing and insulation when the weather is nicer-----
Old 01-25-2013, 07:09 AM   #9
Actually Red, the news reported you guys at -40 yesterday
creeper is offline   Reply With Quote
Old 01-25-2013, 07:25 AM   #10
DIY staff
dang----- -40 c.= -40 F.
I've never seen anything colder than -17 and that caused trouble like crazy---frozen water lines---power outages--the works!
Old 01-25-2013, 07:43 AM   #11
I've felt -25 or 29 or something. I can't tell the difference when it gets that cold. But I do know that after a few days of that 0 degrees feels positively balmy.
I've posted this before. This Canadian girl isn't even wearing a hat
Old 01-25-2013, 07:55 AM   #12
Rewards Points: 84
1970-71 (I think it was) winter survival, I slept on the ground, in a tent, for a week, with overnight lows of minus 20 F. Needless to say, the day time highs weren't a whole lot better. I don't think that we had "wind chill", "feels like", or any of the modern calculations; just the standard "f'ing cold".
Red, we had a fireplace that looked about like that, so I was at a point of adding outside air intakes or sealing it off, and chose the latter. Initially, I closed the damper, lined the back, sides, and top with black foil faced foam (sorry, drawing a blank on the name of it right now), set the rack back in, stacked it with some birch, and it looks as authentic as can be. I didn't have a thermal gun at the time, and have never thought to go back and check it (but may do that now that I am thinking about it), but did hang some tissues in a few places, and it made a big difference in regard to drafts. Maybe not the biggest gap that you have, but a quick and simple fix, and every bit helps.
Old 01-25-2013, 01:15 PM   #13
Wire Chewer
Rewards Points: 90
Yeah we've been hovering in the high 30's and 40's.
I did the water trick the other day too, was cool to be able to try that. We have not had this weather in a while. Used to be standard for January. When I was in high school I've seen what -50 feels like, without the windchill.
Old 01-25-2013, 03:05 PM   #14
Roofmaster
Rewards Points: 2,172
Rigid foam against a firebox? I dont think that is a good idea. Rock-Wool or fiberglass, maybe.
El Nino
, and La Nina, Yes. Al Gore? Bovine Scatology. Watch "Cool It" on Netflix.
PS Who left you with maybe 2 inches of bearing for that lintel in your crawl space?
Old 01-25-2013, 03:46 PM   #15
Wire Chewer
Rewards Points: 90
Even with an electric fireplace? Figured it was a self contained unit and did not get hot on the back. I thought of using roxul but wont that get moldy? Or it it only fiberglass that's prone to that? If I go with one of those I'd also need a vapor barrier then right? That fire box is not exactly perfectly sealed.
some frost on edges of roof sheeting in Attic above garage. Also am getting frost on roofing nails. Sebo20 Roofing/Siding 3 01-20-2013 09:36 AM
Frost on a concrete wall. sbmfj Insulation 11 01-31-2012 11:14 AM
Attic Frost Attic Roofing/Siding 2 01-15-2011 10:19 AM
Chilly inside new construction home katiealbano Building & Construction 2 04-13-2010 11:16 AM
Attic Frost cougar01 Building & Construction 5 01-28-2009 08:33 AM
