Frost Inside Exterior Walls In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-25-2012, 02:42 PM   #1
Advise needed !! Frost inside exterior walls in basement
hello everyone,I am new to this forum and had posted this question in the general topics section,but in hindsight I think I should have put it here.
I have copied and pasted it here, any comments or thoughts are appreciated
We are finishing our basement at the moment. we removed the vapor barrier and insulation to install some wiring and a switch box. I was surprised to find a fair amount of frost on the inside of the walls.
The outside temperature is currently -24 C or 12 below 0 F so I would expect to see some frost on the walls. Do you think the frost in the photo is excessive or normal? the pinkish stuff in the picture is insulation, the frost is white
kanesdaddy is offline   Reply With Quote
Old 12-25-2012, 03:50 PM   #2
Rewards Points: 736
Your structure has a bad air leak causing the frost and possibly a water leak looking at the left portion of the pic.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
kanesdaddy (12-25-2012)
Old 12-25-2012, 04:23 PM   #3
Thank you for the comment I appreciate your thoughts and would appreciate some more of them,so here is some more info for you
The House is new, we had it inspected and could find no leaks. The insulation stops are all ok, and there is plenty of insulation in the attic and there is no water dam on the roof or water leaking through the roof. The house is wrapped in tyvek so we can't figure how we can have an air leak. There are no water lines in the wall anywhere near where this moisture is in the framing. The dark stains on the floor joist look like water stains but are not.
These new homes do not have chimneys, they pipe the furnace and water tank off gasses thru the walls and right outside. Like most new homes they are close together and the "steam" from my neighbours home does at times blow against my home, but we don't think that's the issue.
Any more of your thoughts or comments are appreciated.
thank you
Old 12-25-2012, 04:29 PM   #4
DIY staff
Rewards Points: 7,174
Was that frost uncovered when you pulled out the insulation--or did it grow after you exposed the cold wall sheeting?
Old 12-25-2012, 04:56 PM   #5
the frost was there when i pulled off the vapor barrier and the insulation. I should aslo mention that the moisture is above the basement framing (bi-level) and seems to be in the area on top of the basement walls between the floor joists.
There are 2 heat ducts in the cieling blowing warm air into the basement along this wall, but the rest of the basement has heat ducts too, and its dry everywhere else.
here is a pic of the area in the home where the moisture is. The dark stains on the floor joists look like water stains, but are not.
thank you again for your comments
Old 12-25-2012, 06:51 PM   #6
DIY staff
This is the only thing I can think of that could cause that---there are several insulation/ house sealing pros here---
Let's see if one of them has a remedy.
Old 12-25-2012, 07:19 PM   #7
Rewards Points: 2,634
I see from the send photo that you have insulation and vapor barrier along your rim joist. Just pushing the vapor barrier against the sheathing and stapling it in two or three places is not exactly an air-tight connection. So warm moist air from the living area got behind the vapor barrier condensed on the cold sheathing, and froze. Posssibly that was just a particularly bad spot. Might want to pull open a few more bays and see if they are all like that. My house is done the same way, so I am not saying the insultion was done inproperly, just that it is not perfect. This is an example that I would say is more likely to be close to air-tight....... although from a close look at that first photo, the air leak could be coming from the upper level.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Old 12-25-2012, 07:21 PM   #8
Thank You oh'mike
Here is some more info.
I cut through the drywall on the upper walls of the house above this frosty area and looked at the insulation and the sheathing. It was was bone dry above the area where the moisture is collecting. This should confirm there is no water running down the walls above this area into the lower framing.
The frost/water is only collecting on the exterior portion of the home the floor joists butt up to, nowhere else. It is only frosty on one side of the house. There is no snow or water build up on the exterior of the home that could melt and seep into the structure.
Thank you all again for your input.
Old 12-25-2012, 07:27 PM   #9
DIY staff
It could be as simple as SPS-1 described----warm moist interior air reaching that rim joist---
Air sealing might be the answer-----
Old 12-25-2012, 08:08 PM   #10
Rewards Points: 736
As a temporary test, and if possible, try taping plastic sheeting / visquine to the outside of the house in that location, a few feet in each direction of the frost area, to divert air infiltration and see if that frost diminishes to some extent. If I were a gambler I'd bet this frosty area is on the north side of the house.
Old 12-25-2012, 08:38 PM   #11
Rewards Points: 13,300
Also check to see if they ran the sheathing down past the foundation a min. of 1". You should never be able to see the top of the foundtaion from outside.
Old 12-25-2012, 08:59 PM   #12
Registered User
Rewards Points: 5,244
1. The frost is on the engineered rim joist only, or on the rim and the top plate below?
2. Is the p.t. solid wood plate sitting directly on the concrete or is there a poly sill-sealer material between them? Could be wicking moisture from exterior grade; http://www.greenbuildingadvisor.com/...-building-code
3. How long ago was the house built and did it rain a lot then? Could be wet lumber taking longer to dry between joists- no air movement, temperature difference, etc.
Tyvek requires taping and sealing for an effective air barrier.
4. What type of siding?
5. Any rain-screen air gap?
6. The air barrier on the rim joist should be air-tight as mentioned, foamboard/canned c.c.foam is best to stop infiltrating/exfiltrating air movement (either the inside poly is leaking or the outside air barrier (possibly taped sheathing) is));
http://www.buildingscience.com/docum...l_seal_rev.pdf
http://www.buildingscience.com/docum...ts?full_view=1
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
kanesdaddy (12-26-2012)
Old 12-26-2012, 01:56 AM   #13
The frost is on the rim joist only, none on the top plate
I don't know if the bottom plate has a poly sealer or not, I can't see it wicking from the final grade as the top of the foundation is 16 inches out of the ground
the house is less than a year old, it was not wet when it was built. The homebuilder is all over fixing the problem we are just trying to find the source of the moisture
I can't tell its covered by the siding
vinyl
sorry don't know what that is
air barrier on the rim joist is fiberglass covered by plastic. Gonna have to take off the siding to check the outside air barrier
Gary
Thanks for taking the time to ask these questions.
Old 12-26-2012, 10:39 AM   #14
AHH, SPANS!!!
Rewards Points: 1,166
I see the answer above, vinyl siding.That was my fist thought when reading the thread. You are getting a leak , most likely at the bottom of the wall where the vinyl siding starts.On the exact opposite side of the frost or in the immediate vicinity look up behind the bottom course of siding and you will see the problem.
hand drive is offline   Reply With Quote
Old 12-26-2012, 11:32 AM   #15
The house is a bi level, so the bottom course of the siding is well below the area where the moisture is collecting. That said I wouldn't be surprised if it is an exterior seal problem.
Any suggestions on how to find an air leak into the house?
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Basement wasls, vapor barrier , options for what i have to work with bf514921 Building & Construction 3 07-13-2012 12:26 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
insulate inside basement closet? qchawkfan Building & Construction 2 01-08-2010 10:20 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
