Old 01-09-2011, 10:55 PM   #1
Wire Chewer
Red Squirrel's Avatar
Frost on crawlspace walls
I have a crawlspace under my garage, it is only about 3-4 feet under ground, so it's completely in the frost zone. i occasionally go in there to clean spider webs. This is the crawlspace, before the first time I ever been in there. I have a phobia of spider webs. VERY long stick, and shop vac is used.
I noticed chunks of frost on parts of the wall. It's not exactly a straight wall and I can tell there's been lot of movement over the years. The home inspector saw that when I bought the house and said to keep it heated which I've been doing but the heater is set quite low so I may need to increase it. Keep in mind this house was built in 1965 so I think it's still in half decent condition for it's age but not as nice as the main crawlspace which only has a bit of movement and some efflorescence. Not more then that.
Now, can I safely insulate this crawlspace? Or will insulating it cause problems? I'm planing to get a company to just apply spray foam. I know the proper way to fix this problem is to probably insulate from outside, but hoping doing it from inside can be acceptable as well and wont cause the walls to freeze even more behind the foam as there will now be a lack of heat getting to them.
Old 01-09-2011, 11:53 PM   #2
nap
You talking to me?
nap's Avatar
you missed a HUGE spider in there. It's over to the right in that shadowed area way down almost to the bottom of the picture.. It looks like it is looking right at you. Must be waiting for you to crawl on by so he can jump on you.
Old 01-10-2011, 12:11 AM   #3
either those are grape vines, or you have some spiders that ought to be respected. maybe you need a 410 w/ you whilst under there??? were i u, i'd read on buildingscience.com about your options.
Old 01-10-2011, 02:04 AM   #4
Wire Chewer
The spider problem is mostly taken care of now but yeah it was quite something when I first got the house.
The nice thing is because it's so cold in there they're not really active in winter, as far as I know.
Also another thing, I used non PT lumber against the wall so I can mount electrical. Do you think I may have rot/mold issues? I really should have used PT I think... the wall it's on is actually an inside wall though, so the other side is still in the house. Should be ok right? There was no frost on that wall, just a few spots on other walls, mostly corners.
Old 01-10-2011, 03:13 AM   #5
I'd have to guess on the PT wood. "The rule" is to have PT wood against any concrete that might even think about getting damp. My worry would be that "there is no dampness" but the 'crete is wicking moisture from the soil and it is evaporating at the same rate. That moisture could wet a board that reduces the airflow to the 'crete. I'd stick w/ PT anywhere that may even get "humid" and run the elect through PVC pipes nipples in the studs, or whatever you'd have to do. I have PT in my basement, and just ran the electrical like normal. I used galvanized boxes, and it has been working for 30 yrs. That said, I don't recall that I've pulled an electrical box and looked at it, either. Hmmmm.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Clean crawlspace cinderblock walls (prep for sealing)? syntax53 Building & Construction 1 07-20-2010 02:12 PM
Questions about sealing a crawlspace. John_W HVAC 5 07-11-2010 03:24 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
