Front Porch Over Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 01:32 PM   #1
Rewards Points: 85
Front porch over basement
I've posted about this topic before, but still do not have a good solution. I have an 85 year old house with a front porch built over the basement. The porch decking is original (I assume) and doesn't hold paint well as it has started to rot in places. I'm going to replace the decking and have considered either PT southern yellow pine, or a composite t&g porch decking. Problem is that it needs to be more or less waterproof since it sits over the basement and receives blown snow/rain from time to time. It currently leaks on occasion. I can't put in a sleeper system since the door sits flush with the decking. The manufacturer of the composite recommended layers consisting of 1/2" exterior grade plywood, HT ice/water shield, and then the decking with silicone between the grooves. As this is over the basement should I be concerned about the decking rotting from below if I seal it up from the top? Any suggestions would be greatly appreciated.
Old College Try is offline   Reply With Quote
Old 11-05-2013, 03:03 PM   #2
Hello,
I am having a similar problem but I am able to add sleepers (Open porch built over basement and garage- porch rot). I am curious how you ended up dealing with your porch.
JohnMargaret is offline   Reply With Quote
Front porch column help JRigby Remodeling 1 02-18-2012 02:09 PM
Front Porch Roof Angle slakata Roofing/Siding 12 08-26-2011 08:46 PM
Operation Front Porch = Outdoor room Complete! Leah Frances Project Showcase 14 04-27-2011 09:14 PM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
