Front Porch Crosshatch. Alternatives To The Same Old 45 ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 08:24 AM   #1
Rewards Points: 117
Front porch crosshatch. Alternatives to the same old 45 ?
My existing PT cross hatch under the front porch is falling apart. Before I replace it with PVC white of the same, is there a better alternative?
It just seems like the old 45 crisscross is a little over done and blah.
tgm1024 is offline   Reply With Quote
Old 11-07-2011, 06:04 PM   #2
Knucklez's Avatar
Rewards Points: 932
i was reading a deck book recently that had a really neat idea, though not sure if it is diy or not.. but anyway, they had a brown coloured composite deck and took two 16' pieces of white compesite and sandwitched it between some pink insulation batts. then they put a heater along the length in the insulation sandwitch and measured the temp until certain temp was reached and held it there for a bit. then, when they took it out it was completely moldable so they made a figure 8 out of it (clamped in a form until it cooled & hardented). then they putt on the brown deck and traced it out and then cut the brown deck along the trace and then incerted the white composite figure 8. looked pretty cool.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 11-07-2011, 06:23 PM   #3
Framing Contractor
Rewards Points: 120
Spice it up with some details
sixeightten is offline   Reply With Quote
Old 11-07-2011, 07:44 PM   #4
Rewards Points: 117
Huh....that picture is interesting: They brought the crosshatch right to the corner of the porch where it met the other side. There was no trim in the corner. That's different from what I've seen before.
Old 11-07-2011, 07:46 PM   #5
Rewards Points: 117
Knucklez
That really would be an interesting inlay into the decking itself. I'm talking about the crosshatch in front (visually below the deck).
Old 11-07-2011, 08:41 PM   #6
kwikfishron's Avatar
Rewards Points: 612
There’s all kinds of different details you can do. I’m actually doing one now that will be a sectioned raised panel look that will work nicely for “this house”, maybe not yours though.
Post a picture from a street view of the porch and house.
kwikfishron is online now   Reply With Quote
Pre-planning: converting front room back to porch WillK Building & Construction 3 11-06-2011 12:47 PM
Front Porch Flashing? kcrossley2 Building & Construction 7 07-23-2011 02:13 PM
Front Porch - Repair or Completely Replace? DIYerIT Building & Construction 1 05-26-2011 12:58 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
New Circuit to outside front porch - need help Leah Frances Electrical 12 05-13-2010 03:12 PM
