Old 08-31-2010, 09:45 AM   #1
Front Porch
I am constructing a covered front porch on a colonial home using 1x6 tongue and groove mahagony for the floor. Unfortunately I have had no luck finding resources either in bookstores or online as to the proper construction. I have managed to figure out the answers to most of my questions, except one. Most of the pictures I have seen of porches like to one I am building have the floor planks going perpendicular to front door rather than parallel. Is there a reason? I know that the floor has to go perpendicular to the joist but is there any reason to have the joist run parallel to the door and the floor perpendicular?
harrington85 is offline   Reply With Quote
Old 08-31-2010, 11:44 AM   #2
fabrk8r
fabrk8r's Avatar
Front Porch
The main reason porch boards run perpendicular to the house is to eliminate butt joints.
There is no reason you can't run the boards parallel to the structure, and some people prefer the way that looks.
One possible benefit to running the boards perpendicular is to aid water run-off...but I don't think it matters very much with today's wood preservation products. My own 30' wide by 10' deep porch, which was built in 1908 using 3" tongue & groove pine, was installed perpendicular to the home had only a few areas that needed replacing after 100 years. It has about 1/8" to the foot of slope away from the structure.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-31-2010, 01:58 PM   #3
Moderator
Front Porch
Early porches were built for water run-off. My Craftsman porch, 1910, has the boards perpendicular to house, otherwise the edge would slow or stop water to rot. I replaced a 6' section and used some butt joints (every third one) to match the original planking layout. The joists are always pitched.
Gary
Clothes taking longer to dry?
Building a front porch and have questions... SolidStateS15 Building & Construction 9 07-10-2010 05:16 PM
New Circuit to outside front porch - need help Leah Frances Electrical 12 05-13-2010 04:12 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 12:14 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
