Front Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2006, 03:53 PM   #1
Front porch
I like to ask if it really matters if I frame my front porch floor with either pressure treated or douglas fur or simular wood ?
wirenut is offline   Reply With Quote
Old 08-17-2006, 12:42 PM   #2
robertcdf's Avatar
For framing material I dont use anything but PT. As well as SS hangers and nails. It's the only way to do it right.
robertcdf is offline   Reply With Quote
Old 08-18-2006, 01:11 AM   #3
Carpenter
DecksEtc's Avatar
Agreed. PT is also the most economical choice for framing any deck.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 08-19-2006, 12:13 PM   #4
Thanks for the reply, I was also told as long as I dont close in the front porch to the house that pt is the way to go! Now its time for the demo & dumpster.
Old 08-19-2006, 05:42 PM   #5
pt
redline is offline   Reply With Quote
Old 08-21-2006, 01:02 PM   #6
Well porch is now in the dupster but the way it was built is surprising that it stood as long as it did. They used 3/4 pine x 6" boards boxed it with nothing inside to hold up a roof that is 22ft long x 8ft . The bases were all rotted away.
Old 08-27-2007, 01:33 AM   #7
i want to enclose my front porch. it is on cinder blocks about 2.5ft high. there is a concrete slab about 3 or 4 inches thick. Can i build on the concrete or should i bust out the concrete first? i heard the floor might be cold in the winter if i leave the concrete slab there
bobbyt43 is offline   Reply With Quote
Old 08-27-2007, 06:44 AM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
First off, the answer depends on what part of the country you live in. If you live in a cold climate, the walls should be (enclosed) - sitting on top of freezewall footings extending 3 to 4 feet below grade to avoid heaving.
- Build Well -
Repainting Columns on front porch R Parker Painting 10 04-17-2006 09:37 AM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 10:33 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 05:20 PM
