Front Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 02:04 PM   #1
front porch
how do i make foundations for piers/posts to support a front porch ?
jdreano is offline   Reply With Quote
Old 10-13-2012, 02:59 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
They would need footings dug into the earth, depth determined upon your location. If they are piers,how big are the piers ?
hand drive is offline   Reply With Quote
Old 10-13-2012, 03:58 PM   #3
GBrackins's Avatar
Rewards Points: 2,086
first are you required to file for a building permit? if so, pier construction is not prescriptive code in most areas that use the International Residential Code. Put a call into your local building department to find out.
with that said your footing must be able to support the weight of the construction it supports (dead load - weight of building materials) together with all other imposed loads such live load (people, furniture, snow, non-permanent loads). The size of the footing is based upon the total load and the soil bearing capacity of your soil.
footings must be supported upon undisturbed virgin soil with a depth at least meeting your frost depth (ask building department for yours). You may need to go deeper depending on the type of soil at your frost depth.
Pier may be either square or round (sonotube type) and typically are reinforced with steel reinforcing bars to resist any lateral loads.
you may find some helpful information in this link http://www.front-porch-ideas-and-mor...undations.html
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Operation Front Porch = Outdoor room Complete! Leah Frances Project Showcase 14 04-27-2011 09:14 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
Building a front porch and have questions... SolidStateS15 Building & Construction 9 07-10-2010 04:16 PM
Sanding and painting front porch ciera Flooring 2 08-29-2009 07:52 AM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
