Front Landing Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 08:19 AM   #1
the Musigician
DangerMouse's Avatar
Front landing questions
approx. 40"x48" landing, 32" high. Is there a min./max. height the handrail needs to be from the landing floor?
Thanks guys!
DM
Old 07-27-2011, 08:27 AM   #2
kwikfishron's Avatar
Rewards Points: 594
36" min.
kwikfishron is offline   Reply With Quote
Old 07-27-2011, 08:43 AM   #3
the Musigician
Thanks Ron. I thought that was it.
The thing is, I have some PT 4x4s that might be long enough IF i lower the landing so you have to 'step up' into the doorway. That IS allowed, right?
It'd also keep snow from piling up against the door. Then it would be about 24" high and one less step on the stringers. Is this ok?
DM
Old 07-27-2011, 08:46 AM   #4
Rewards Points: 774
DM
I would think that would be IDEAL. Our deck is only 2 inches lower than our entrance and with any snow it poses some issues. Just make sure the step up isn't any more than a normal riser on a stair....about 7 inches.
cibula11 is offline   Reply With Quote
Old 07-27-2011, 08:48 AM   #5
the Musigician
Thanks, this is the LAST "inspect-able" thing I have to do, so I need to get it right the first time.
DM
Old 07-27-2011, 08:51 AM   #6
Rewards Points: 594
If your talking about 1 step from the landing into the door you should be fine.
Old 07-27-2011, 08:57 AM   #7
the Musigician
Yup, one step up into the foyer. What min. size 2x? do I need on the simpson hangers underneath to support the landing 2x*whatevers*? (probably will use 2x8 for the landing and steps?)
DM
Old 07-27-2011, 09:18 AM   #8
Rewards Points: 594
2x6 would be fine for a 4' landing.
Old 07-27-2011, 09:54 AM   #9
the Musigician
I have one 16' 2x8 for the outside so I figured I'd just get another one for the joists and steps.... overkill?
A couple extra bucks to make me feel better won't hurt.... TOO much.
Thanks again!
DM
Old 07-27-2011, 02:18 PM   #10
Rewards Points: 594
How are you using 2x8 for the stairs? You can’t cut stringers out of them.
Old 07-27-2011, 03:47 PM   #11
the Musigician
I can get precut stringers delivered with the extra 2x8s, that's no concern.
DM
Old 07-27-2011, 03:49 PM   #12
the Musigician
Do I need 2x10s for the steps?
DM
Old 07-27-2011, 04:12 PM   #13
Rewards Points: 594
You don’t need 2x8 for the joist but you certainly can since you already have some of it.
2x10 isn’t wide enough for the tread, go 2x6 two deep for a 11” step.
Are you sure about the pre-cut stringers?
Old 07-27-2011, 04:14 PM   #14
AGWhitehouse's Avatar
Originally Posted by kwikfishron View Post
2x10 isnít wide enough for the tread, go 2x6 two deep for a 11Ē+ step.
2x12 treads aren't great for exterior as they don't drain rain as well as (2) 2x6's with a gap in the middle. If the 2x12 cups, then you'll have puddled steps.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-27-2011, 04:20 PM   #15
Rewards Points: 594
What did I say?
Replacing deck...questions... mgh-pa Building & Construction 8 05-27-2011 07:11 PM
Front steps redesign questions moe67 Landscaping & Lawn Care 3 05-01-2011 12:40 PM
Need opinions/feedback for front sidewalk and water drainage idea (photos) HautingLu Landscaping & Lawn Care 2 04-29-2011 10:58 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 08:47 PM
