Old 08-28-2009, 08:18 PM   #1
Front landing leaking into basement when it rains
Hi,
I have brick front landing that needs some repair. The landing is a trapezoid, 8' on the long side, 6' on the short, and about 5' between them. The landing is centered over the foundation, so 2 1/2' of the landing is the basement ceiling.
The brick and mortar is very old and chipped, and much of the wood siding touching the bricks has rotted from moisture. There is at least some flashing underneath, since when I took some baseboard trim off, I saw it. However the seam was lined up the the seam in the trim work instead of going around the corner.
In the basement, the ceiling has what looks like duct work below the bricks, which has opened up, and I can see about a 3/4" layer of some hard substance, which has holes in it, so it doesn't appear to be anything for waterproofing.
When I ran a hose on the steps, I could see water coming in from inside the "ductwork", and on the wood on the outside of the "ductwork".
I've received some quotes to have the steps redone, but I'm not sure they're qualified to resolve the leaks. I want to be sure that when I redo the steps I'm not going to have any more problems.
Here are my questions:
1. What's the proper way to water proof under a brick landing?
2. Is it likely that the leak is coming directly through the old mortar?
3. What are your recommendations for me to resolve this issue temporarily?
4. If I redo the landing, what are the advantages of brick vs pavers vs bluestone? Any other suggested step material?
5. Should I rip off the steps or try to patch it?
6. Any other general comments would be greatly appreciated.
Thanks.
cwyse is offline   Reply With Quote
Old 08-28-2009, 11:07 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Photos?
Old 08-29-2009, 08:04 AM   #3
Hi,
Here are the photos. I have larger versions if they are needed.
Chris
Old 08-29-2009, 12:07 PM   #4
long island, NY
one thing that would help would be to redo the front steps and make sure it pitches slightly away from the foundation. From the pic, it looks like it settled in a manner that permits water to pool on the steps and possibly even flow towards the house....
diy'er on LI is offline   Reply With Quote
Old 02-26-2010, 05:58 PM   #5
Did you ever resolve your problem with the brick steps? I have a similar issue where my front steps are directly in contact with my basement foundation/box frame holding up the first floor joists. I'm convinced water is seeping through the bricks, I'm going to try and seal the brick steps this spring with "Defy Water repellent for brick".
jkitchen is offline   Reply With Quote
Old 02-26-2010, 06:05 PM   #6
this is like reading a ticker tape...sheesh
The older I get the better I was
Old 02-26-2010, 06:59 PM   #7
Xtreme DIY'r
Please start a new thread
This one is impossible to read
**OK - never mind fixed it
Old 02-27-2010, 09:36 AM   #8
are you certain you fixed it OR just stopp'd it for now ? what'd you do ?
itsreallyconc is offline   Reply With Quote
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 08:42 AM
condensation leaking in basement! geniedee HVAC 3 08-25-2006 08:58 PM
Leaking basement.. MRHOCKEY2434 Building & Construction 1 12-29-2005 06:07 PM
leaking basement jdwdwd Building & Construction 3 01-22-2005 09:44 AM
