Front Entrance Cover - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 11:44 PM   #1
Front entrance cover
The stucco of my house has been stripped down and I am going to redo the stucco.
Before that, I want to build a front door entrance cover like this:
(I found this picture on internet.)
However I don't have a clue where to start. How much does it cost to ask for somebody to make a drawing like this for me? Or where should I start to look for the right personal to help?
BTW, I live in bay area. Thanks a lot for any suggestion!!
pttcc is offline   Reply With Quote
Old 09-23-2010, 06:51 AM   #2
it's a simple "shed roof" supported by brackets underneath and a ledger on the house, with terra cotta shingles.
all you really need to figure out is the design of your brackets, both spec'd for size/load, as well as material and shape, and the design of your fascia or trim along the outer edge.
from there it's a simple shed roof.
not sure if those pilasters are serving any structural purpose of supporting the brackets, or if they're just decorative. i would guess decorative, and the brackets are bolted onto the studs.
good luck.
wombosi is offline   Reply With Quote
The Following User Says Thank You to wombosi For This Useful Post:
pttcc (09-23-2010)
Old 09-23-2010, 07:21 AM   #3
Rewards Points: 5,336
Considering you live in earthquake country, you would need a structural engineer or an architect.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
pttcc (09-23-2010)
Old 09-24-2010, 12:07 AM   #4
Does anyone recommend a carpenter or architect to help this project? Or can anyone give me a detailed drawing? It doesn't have to be exactly the same. I would love to pay for a doable one.
Old 09-24-2010, 08:05 AM   #5
Any worthwhile,"detailed" drawings would come from an engineer or an architect based on the locales building requirements.
Ron
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Drying time and painting a front door gramps416 Painting 1 05-17-2010 11:01 AM
Radiator Cover Fix zetti1102 Carpentry 5 03-10-2010 10:31 AM
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 12:40 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
