Front Door Purchase/installation Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 08:32 PM   #1
Front door purchase/installation help
I recently bought a house, and need to replace the entrance/main door. The door is 32" by 80" (actually 31 7/8 by 80). Can I just buy a door slab at Depot/Lowes and it will just go right in, or do I need to buy a pre-hung door and re-do everything? I have 2 arch ways that come out right next to the door frame, so I REALLY do not want to mess them up. I was talking to the one associate at Depot and he told me I need a custom ordered door b/c at 32" x 80" door is actually 31 1/2 by 79 and it will be too small for mine. Any help would be greatly appreciated.
PS: This is my first time posting on here so I hope I am doing it right...
Thanks!!
Tom
twatkins05 is offline   Reply With Quote
Old 05-13-2013, 08:42 PM   #2
Roofmaster
Rewards Points: 2,172
The "Associate" is an Idiot. A 2-8 is a standard size door.
Old 05-13-2013, 08:52 PM   #3
That's what I thought. So I can just buy a slab and throw it in, right?
Old 05-13-2013, 09:03 PM   #4
Rewards Points: 13,458
Nope, a slab is going to be a whole lot more work then a prehung.
Hinges need to be mortised, knob hole needs to be bored and mortised.
If off just a little bit it's not going to work.
Use the old door as a template.
Old 05-13-2013, 09:27 PM   #5
OK I'll go with a prehung. Any advice as far as getting the old frame out or putting the new one in? I've been doing a bit of research on it. I know I have to shim it and level everything.
Thanks for the quick responses! I'm liking this site so far!
Old 05-13-2013, 09:28 PM   #6
MJ Force's Avatar
Rewards Points: 150
If you have to buy a slab, find a door store, buy the slab from them, bring in your old door and have them match the mortising and latch holes. Attach the hardware and install it yourself. Be prepare to make some small adjustment to the hinges and frame striker location though because it may not be perfect.
A prehung door is easier sometimes.
Ps.edit; Ok I was slow in my response.
MJ Force is offline   Reply With Quote
Old 05-13-2013, 09:39 PM   #7
Posting a picture will go a long way for getting some suggestions on how to remove and replace.
Squaring a walkway off the front steps? Boiler98 Building & Construction 3 07-14-2012 08:31 PM
Replacing a concrete front door approach with a boardwalk? bigdaddydavy Building & Construction 10 05-31-2012 09:08 PM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 06:08 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
