-   -   Front door installation - couple q's (http://www.diychatroom.com/f19/front-door-installation-couple-qs-10421/)
joeyboy 08-04-2007 05:04 PM
I have a solid wood, completely unfinished slab for my front door (6 square patterns, but just raw wood).
Is this the general way to approach this?
1) drill holes for peep hole, door knob, etc; prep/chisel for size, and for hinges
2) primer (is primer necessary if I later top coat with sealer?)
3) paint
4) clear coat (polyurethane I think) my satin finish (using matte red paint, I want it matte most other places so will be using the clear coat to make it satin)
5) install doorknob, peep hole, etc.
6) install into door frame
Is that basically on point? Again, this is just a slab front door, no frame or anything, it'll just be going where the old door was, on the old frame. I guess my main points of confusion are whether or not I need primer if I'm sealing it after the paint, and if my order of paint/drilling/etc is proper.
MinConst 08-04-2007 08:33 PM
Your plan sounds good but yes you need primer. Primer seals the wood so paint doesn't soak in. Top coat clear will seal and protect the paint.
Make very sure all holes, hinges are correct. Hang the door, make sure all is good then take it down and prime/paint/finish. Or paint when it is hung.
Joining_Heads 08-06-2007 09:12 PM
When finishing exterior doors I always remove all the hardware and lay it out on horses. That way every part is sealed.
And yes, your plan is sound.
PS.. If you have a router, a hinge jig will make setting the hinges a breeze.
joeyboy 08-19-2007 02:35 PM
Can you elaborate on the 'top coat clear will seal and protect the paint'? In another thread I was asking about a satin coating and told that you *do not* do coatings over the paint, the paint protects itself, and doing so would lead to less than stellar results :huh:
