French Windows Rattle In Studio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 02:49 PM   #1
Question
French Windows rattle in studio
In my music studio, I have two large french windows. The window itself is very thin, and is constantly buzzing and rattling from my subwoofer in the room. Turning down or eliminating frequencies from the subwoofer is not an option because I am using the setup for music production.
I have tried everything from applying magnets on the windows, to tightening the frame by nailing the edges to grip the glass better. The rattle/buzz continually changes position and always comes back. I would like to get rid of the problem without taking the entire frame/window apart as this would be a huge project.
The best method I have discovered to prevent the rattling, is when pressure is applied directly to the glass with a few fingers. I apply no more than 3-4lbs of pressure before the rattling completely stops. This is where I need someones help....
I am thinking of using some type of bracket that can be screwed onto the outside of the window frame. This bracket would have a piece that extends to the middle of the window, and would have a treaded hole. Through this hole I would like to insert and screw in some type of metal rod, the rod would have a rubber pad/square at the end of it. This would allow me to screw in the rod and apply proper pressure on the glass to prevent the rattling.
Any help, products, tips, ideas would be greatly appreciated. Thank you so much!
markstewe is offline   Reply With Quote
Old 11-17-2009, 06:59 PM   #2
Rewards Points: 5,336
Why can't you put a sheet of acrylic plastic over the glass? You could place the sheet on spacers so the woofer pressure would not impact on the glass.
Ron
Old 11-17-2009, 07:44 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Ron
I'll second Ron's suggestion. HD carries acrylic panels.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-17-2009, 07:44 PM   #4
I'm not quite sure how that would work. The glass itself is attached to the frame, you are saying put spacers on the window and attach the sheet? I think it would still vibrate...
The glass needs to be pressured and forced not to vibrate. Leaning a heavy piece of plywood on the window does work, although I would like more pressure than that because it still has light buzzing with that method. The plywood choice is possible but very unpractical...
Please fill me in, sorry if I misunderstood. Any other suggestions are greatly appreciated!
Old 11-18-2009, 09:10 AM   #5
The theory was if air pressure was creating the vibration then putting something in front of the glass would deflect the air from getting to the glass. The spacers would allow an opening so the pressure against the plastic wouldn't create an internal pressure to the glass.
If the vibration is coming through the frame to the door and vibrating the glass, then the plastic wouldn't work.
You need to experiment to see how these vibrations are getting to the glass.
Ron
A possible solution using your pressure points on the glass would be to glue posts on the plastic with rubber tips that would apply pressure to each pane. You could use acrylic rods to minimize the visual.
Old 11-18-2009, 12:29 PM   #6
Well the subwoofer is right next to the window, so its definitely coming through the frame/ground and rattling the window. Unfortunately I can't use another setup, my only option is to apply pressure to the glass. Any other suggestions would be greatly appreciated!
Tags
buzz , frame , rattling , window , windows
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 09:56 AM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
New Windows installed over old windows Lakehome Remodeling 1 03-14-2009 02:39 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
