Old 05-29-2010, 11:43 PM   #1
French drain tile exterior wall
had only one wall excavated want to install french drain tile. Have little money & excavating this wall was free. Heard a lot of suggestions but now I'm scared I can't make a productive drain system with only one wall excavated. Have no sump pump, can't afford at time. Do plan on doing in near future. How can I best make use of this one wall excavated. HELP!!!
lsaucy is offline   Reply With Quote
Old 05-29-2010, 11:54 PM   #2
Xtreme DIY'r
Please do not start multiple threads on the same subject
The "How To" forum is not intended for asking questions
Old 05-30-2010, 07:17 AM   #3
if you have no $, life becomes much more difficult - especially when 1 owns a home,,, you're absolutely right - 1 wall does not a drain system make,,, you have 0 $$$ ? ? ?
will await your answer prior to posting again !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is online now   Reply With Quote
Old 05-30-2010, 12:48 PM   #4
Concrete & Masonry
You have 3 options that I can tell from you're limited info:
- Exterior sump pit & crock.
- Interior sump pit & crock (My preference on most jobs)
- Drain tile to daylight/grade. (Maye lot's more digging)
Just know that water does not discriminate according to wealth, it doesn't care. Odds are that the water will find it's way to the base of the wall faster than beforenow do to the recent excavating, and subsequent loose backfill. You NEED to have a route to remove this water in place period.
jomama45 is offline   Reply With Quote
Old 05-30-2010, 05:22 PM   #5
btw, for an exterior pump, elec code requires a separate gfci protected line.
Tags
french drain
Building a french drain gruntman Landscaping & Lawn Care 23 06-01-2010 08:59 PM
French drain help 11 boman47k Plumbing 1 05-03-2010 10:20 PM
How to Finish Tile Floor around Drain Hole atm Tiling, ceramics, marble 3 09-12-2009 11:39 AM
proper location of outside drain tile 4just1don Building & Construction 3 08-30-2009 11:16 PM
french drain - street curb ansatzjp Landscaping & Lawn Care 4 12-15-2007 05:06 PM
