French Drain Pipe Material & Filter Cloth Decision - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 07:45 PM   #1
Rewards Points: 12
For French drain (dual-pipe) installation in heavy clay soil situation in northern CA, what are your recommendation/experience regarding the following:
1. Pipe
4" Styrene (white) vs 4" SCH40 vs 4" SDR35
It seems cost-wise, it's SCH40 > SDR35 > Styrene. Well-reputed installer claiming that Styrene performs the same as SDR35 at half cost, and used for years. I'm aware that SDR35 is thinner-walled and used for low-pressure DWV application, as compared to thicker-walled SCH40. Just not sure how Styrene compares against SDR35. Was told that white Styrene is not the black ABS (Acrylonitrile Butadiene Styrene). There is no car traffic over the path of subterranean trench, except for a section underneath concrete driveway. Is it only $0.50/ft more for SDR35 vs Styrene? Wanting to make sure it will not be bended/intruded by roots in time.
2. Filter cloth
Yay or Nay
I read various accounts of advising not lining the trench with filter cloth in clay soil installation. The reason is that clay soil will cake up the filter cloth in time when wet, therefore preventing water percolating thru gravel and reaching the perforated pipe at the bottom of the trench.
Thanks!
RX8tasy is offline   Reply With Quote
Old 10-25-2012, 09:09 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
I typically use perforated SDR-35 (typically used for a septic system leach field) with the holes down and no filter cloth. as ground water rises it is picked up by the pipe. with the holes down an sedimentation picked up will settle out of the pipe.
everyone has their preferred way of doing things ......
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 12:28 AM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
French Drain Help Please moze Landscaping & Lawn Care 19 02-16-2011 11:09 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
