French Drain Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 05:11 PM   #1
french drain install
installing perimeter drain in full basement and floor slab is even with top of footing. What is the best way to make this work
jay czap is offline   Reply With Quote
Old 09-29-2011, 05:53 PM   #2
Civil Engineer
Rewards Points: 4,790
The invert of your perimeter drain needs to be at least 6 inches lower than the slab, preferably more like 12 inches lower. If the footer gets in the way, simply move the perimeter drain sufficiently far from the house so the footer does not interfere with installation.
Old 09-29-2011, 08:14 PM   #3
Knucklez's Avatar
Rewards Points: 932
think about the slope you need to reach the sump and make sure at the low end the drain is not lower than your footer (don't want to undermine the foundation!).
other things to know about install depends a lot on if your basement is already finished or has exposed foundation walls, what type of wall is it (cinderblock, stone, ICF etc.), and perhaps most importantly what problem you are trying to fix!
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 09-29-2011, 08:29 PM   #4
Concrete & Masonry
Rewards Points: 582
Gotta say, I don't envy you. In 20+ years, I've never seen a basement floor that didn't sit on the footing here, only in some rigged-together crawlspace addition. I can't imagine how the floor to footing joint would ever stay in this scenario.
jomama45 is offline   Reply With Quote
Old 09-29-2011, 08:30 PM   #5
concretemasonry's Avatar
Rewards Points: 2,608
Interior drain tile should be installed level. Water always seeks the lowest level, besides it is an "open" system because the pipe has holes at 4:00 and 8:00.Just make sure you have a couple of inches of well draining fill under the ppe to increase the effective draining area around the pipe.
Also, a filter barrier between the existing soil and the the well graded, clean back fill material (not just big rock).
Dick
concretemasonry is online now   Reply With Quote
Old 09-30-2011, 04:37 AM   #6
Rewards Points: 4,656
we use # 57 stone to bed & cover the pipe,,, IF you can create a slope to the pipe, falling water will help to keep it cleaner than a flat pipe & gravity water OR so it seems to us - 1":10' seems standard
French drain or perimeter drain sbmfj General DIY Discussions 4 09-16-2011 09:52 AM
future paver patio over old french drain? D270 Landscaping & Lawn Care 0 08-21-2011 10:28 AM
French Drain Help Please moze Landscaping & Lawn Care 19 02-16-2011 11:09 AM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
Interior French Drain cougar01 Building & Construction 3 03-29-2009 11:51 AM
