French Double Door ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 10:27 PM   #1
French double door ?
Alright my house was built in 81 the back has a huge deck but the back door is a standard 32 inch door there is 20 inches between the door and a window . I want to put a french door in there . but the design of my house uses the exterior walls to support all of the roof's weight . I guess my question is will there be a header the length of the window and door or 2 separate headers ?
Will I need to support the roof with a frame before I start ?
Wwildman is offline   Reply With Quote
Old 07-28-2012, 10:29 PM   #2
Framing Contractor
Rewards Points: 98
It is doubtful that there would be one header there. Yes, you will need to support the structure to install a new properly sized header.
sixeightten is offline   Reply With Quote
Old 07-28-2012, 10:32 PM   #3
What is a good size to use for a header for a french door ?
Old 07-28-2012, 10:38 PM   #4
Framing Contractor
Rewards Points: 98
That question would need to be answered by someone on site. It will depend on what the header will be carrying. Roof? Floor? Floor and roof? How much of each? It could be as easy as taking some measurements and photos to a local lumberyard. Check with your local building department to see what is required for your area.
Old 07-28-2012, 10:41 PM   #5
It will only be supporting the roof I live in a single story house
Old 07-28-2012, 10:45 PM   #6
Framing Contractor
Rewards Points: 98
What is the pitch of the roof? What is the span of the members? What are the roof load requirements for your area? We get these questions all the time here. It is impossible for anyone here to size that beam without actually being there. Guessing is not good when it comes to beams, and oversizing just gets expensive. There may also be some hardware considerations for your area that differ from mine.
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Replacing double pane french door glass inserts Double Windows and Doors 2 06-26-2012 09:59 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
Samsung French Door - Door flap broken - Help Leah Frances Appliances 4 02-15-2009 07:53 PM
