-   -   French Doors - Locking Dummy Levers (http://www.diychatroom.com/f19/french-doors-locking-dummy-levers-12135/)
highflyguy 10-05-2007 09:15 PM
I am wondering if someone can help me. I am a mortgage broker and work out of my home. The company I use for credit is requiring a site inspection, and one of the parameters is a "locking office."
I have a set of French Doors...I am not sure of the correct terminology, so I apologize. There is nothing for the doors to close into...no wood support that runs from the ceiling to floor. Basically, the doors go into a groove at the top, which holds them in place. As a result, the doors have dummy handles, which do not turn. Does anyone have a creative way to make them lock, without ruining the doors (and without just using a chain and padlock!)? I appreciate your help!
troubleseeker 10-05-2007 09:39 PM
A "locking dummy lever", by it's own definition cannot exist. One door in this situaton is fitted with slide bolts mortised into the edge of the door at top and bottom so that the door is the pinned to the floor and top jamb; or surface mounted slide bolts used to do the same thing. This then allows a standard lock to be installed in the other door.
Sammy 10-07-2007 06:44 PM
One door would have to be fit with some surface or flush bolts to lock it to the frame. Then the active door can be locked with a normal door lock.
Ron6519 10-08-2007 08:05 AM
As Sammy said, you can get slide bolts that go into the frame. They can be decorative and surface mount onto the interior flat of the door or if you want to minimize the visual you can mount them on the latch surface, top and bottom.
Ron
Jeekinz 10-08-2007 10:35 AM
Is there another door in the room? You could install a set of door bolts that insert into a mortise in the floor and exit from another door.
