French Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 02:48 PM   #1
MXer
3 legged dog's Avatar
French doors
Is there a code as to which way french doors open. Mine open in, my inlaws open out. Mine were installed by previous owner, and my inlaws were installed by the home builders. I thought I read somewhere that they could only open inward.
3 legged dog is offline   Reply With Quote
Old 12-28-2009, 07:06 AM   #2
Residential code does not require a door to open in or out, but rental and commercial codes are more stringent. I have installed a number of outswing French style doors. They allow more usable space inside the room.
Old 12-28-2009, 08:50 AM   #3
if they open out there needs to be a minimum landing clearance of 36" beyond door arc. This may vary with locality so check code
Old 12-28-2009, 03:04 PM   #4
Registered User
Rewards Points: 5,212
EMERGENCY EGRESS REQUIREMENTS Floor or landing each side of all exterior doors EXC…. [311.4.3] IRC
2 risers OK at exterior door that is not req’d exit……… [311.4.3x]
Floor or landing [at required exit] max 1 in below
threshold EXC………………………………………….... [311.4.3]
Landing [7 in below threshold] OK if door does not
swing over landing.(screen door may swing over)….... [311.4.3x]
Landing min 36in deep x width of door………………… [311.4.3]
Be safe, Gary
Old 12-28-2009, 04:09 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I had out-swing French doors on a previous home. The biggest issue I had was there was no good way to install a screen so you could leave them open in the nice weather. A neighbor had a double screen door on the inside that opened in. Looked kind of s**ty.
Old 12-28-2009, 07:18 PM   #6
MXer
Another thing I noticed on the swing out doors was the hinges were exposed. Seems like the pins could be removed from the outside. Just dosent seem secure.
Old 12-28-2009, 07:20 PM   #7
Outswing doors usually have pins that can't be punched out.
jerryh3 is offline   Reply With Quote
Old 12-28-2009, 07:23 PM   #8
MXer
Good info. Thanks.
Exterior french doors install? imola ghost Carpentry 3 11-16-2009 06:06 AM
Replacing Sliders with French Doors ElizaWhyza Remodeling 2 03-31-2009 11:26 PM
Installing french doors in a load bearing wall johnsan Building & Construction 6 01-03-2009 05:59 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 11:35 AM
