French Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2008, 11:53 AM   #1
French Doors
Hello
We are looking to have French doors installed with access to the garden at the rear. The existing window is 1660 mm wide and 2040 mm height.
There is a gas pipe that runs underneath the window that feeds the fire in the living room.
My question is twofold really.
Will the gas pipe that feeds the fire need to be dug underneath the surface and if so how far down should this go?
If I get a contractor in to do this job (ie install the doors and sink the pipe (if this is necessary)), what sort of cost should I expect to incur?
many thanks in advance. A diagram of the pipe and window is attached.
Chris
ctbjt is offline   Reply With Quote
Old 10-05-2008, 12:39 PM   #2
French Doors
Local code would dictate where the pipe needs to go. Check their first.
I assume you are not in the states since you are using the metric system and I have no idea what the codes are in different countries.
Marvin Gardens is offline   Reply With Quote
Old 10-05-2008, 01:06 PM   #3
French Doors
You are right "Marvin Gardens" I am in the UK and so would need to see what our local building regs would say I guess unless there is someone that views this forum that can help.
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 11:00 PM
Pair of French Doors/ one is warped nyc1dxo Carpentry 8 04-28-2008 08:10 AM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
How much clearance do I need between double french doors? SnowDrops Carpentry 12 11-29-2007 09:54 AM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 11:35 AM
