Freezing Storage Room Next To The Cold Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 04:53 PM   #1
Freezing storage room next to the cold room
Hi,
My cold room does not have any insulation, just concrete walls and floor and it has 2 vents to the outside. Attached to the cold room is my storage room (I have insulated around the door) and the storage room is almost as cold as my cold room, and my basement is very cold too. I am quite sure that the cold is seeping in from the cold room to the rest of the basement. How do I prevent this? Please help!
Van3 is offline   Reply With Quote
Old 01-21-2011, 05:40 PM   #2
Rewards Points: 508
What temperature is your cold room? Do you have any sort of thermal break in that cold room? If money were no object, I would coat the walls with polyurethane spray foam. My second choice would be rigid XPS foamboard with the seams staggered and sealed. You can find the stuff pretty inexpensively. I found a contractor who was retiring and I bought all the 2" Dow foam he had. I would confirm that the cold room is the source of the cold. I have a little IR thermometer that I've used to identify air infiltration and cold spots:
http://www.amazon.com/Black-Decker-T...ref=pd_cp_hi_1
benjamincall is offline   Reply With Quote
The Following User Says Thank You to benjamincall For This Useful Post:
Van3 (01-23-2011)
Old 01-23-2011, 05:50 PM   #3
Thanks!
basement storage room air quality Paranam General DIY Discussions 2 09-19-2009 02:16 AM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 05:06 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 11:51 AM
Adding a vent in cold room... AllGoNoShow HVAC 1 11-21-2006 11:16 AM
