Freeing A Marble Slab From Cement Bed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 03:36 PM   #1
Rewards Points: 201
Freeing a marble slab from cement bed
I'm removing an old fireplace pedestal built in 1951. There is a large slab of marble, about 5 foot by 2 foot, laid in a bed of what seems like cement. I can get the end of a chisel bit on the rotary hammer under the edges, but can't get the slab free without chipping it.
The marble is in nice shape and I'd like to reuse it. Anyone know any tricks to try to get this slab free?
dave11 is offline   Reply With Quote
Old 12-11-2010, 06:22 AM   #2
That's a tricky one. Hit and miss whether you can get it loose without breaking it. Gently work a small chisel around all edges. Try to chip out cement without getting the marble. Good Luck!!!
Old 12-11-2010, 07:56 AM   #3
Rewards Points: 5,336
The only way you'll get this off in one piece is by breaking the seal with the mortar under it. I don't know if you can use a reciprocating saw blade for this. I've seen blades for jigsaws that are used for masonary, but never a sawzall blade.
Localized pressure at the edges will break the stone.
Ron
Old 12-11-2010, 08:06 AM   #4
Rewards Points: 4,586
if you can do this w/it being placed in mortar originally w/o breaking it, you'll walk on water easily
Old 12-11-2010, 09:00 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,070
Ayuh,.... Can you flip it over, 'n bust the concrete off the bottom, without wackin' the marble,..??
Bondo is online now   Reply With Quote
Putting a gas line in cement slab wskiarea Remodeling 2 03-26-2010 06:59 PM
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 10:24 PM
xps and t&g on cement slab? HABSFAN2006 Flooring 10 04-14-2009 07:28 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
