framing window for a flue ?
actually, in my case, it is a very good idea. i frame the opening where the window was taken out. all class a chimney pipe. supported on the outside. the window opening would be just for the pipe to pass to the outside.
my question is = after building a new buck frame. what would i use to fill the space between it and the thimble ? cement board ?
but really, thimbles are put in framed walls all the time.
sides, i may have changed my mind. and will put a hole in the block wall right by the window. class a pipe through the wall. mortar. done
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
