Old 05-20-2007, 11:44 PM   #1
Framing a Wall with a Soffit on Top
Hi all,
I’m framing my basement and I have a question. Can I build a soffit on top of an outside wall? I have pipes running the length of the basement along the outside wall. I want to build a soffit to enclose the pipes and attach the top plate to the soffit instead of the joists. Is that possible? It would be shallow soffit and I could build it with 2x4 instead of 2x2. What do you think?
I would just be so much easier than rerouting all the supply lines.
Thanks for any advise. Seth R.
sethr is offline   Reply With Quote
Old 05-21-2007, 06:49 AM   #2
RippySkippy's Avatar
It's done many times and will look fine when finished. Becareful not to hide those things that shouldn't be hidded i.e. gas pipe connections boxes etc.
RippySkippy is offline   Reply With Quote
Old 05-21-2007, 09:14 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Check out these threads:
framing around ductwork
http://www.diychatroom.com/showthrea...0438#post40438
- Build Well -
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Remodeling a basement can be a big task. When you want to remodel your basement, you first want to think about how big it is and what you want to do, with... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Framing new wall in basement civil_corruption Carpentry 2 02-12-2007 08:23 AM
Framing an angled wall TheBrownsFan Building & Construction 8 01-14-2007 10:22 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
