Framing Wall For Shower Surround - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2013, 05:44 PM   #1
Rewards Points: 91
Framing wall for shower surround
Hey everyone, have a couple of questions regarding a shower insert install im working on.
Will be using a 4 piece kit (shower pan + 3 wall sections) that will go into a corner of the bathroom. The Installation instructions have a diagram for stud installation and thats all easy enough.
I would like to only frame up the wall high enough to support the panels, I do not want to go all the way to the ceiling. I will anchor it into the wall studs and floor joists with screws, but I am concerned with wall movement. I have read that running some of the wall studs down through the floor and attaching them to the joists helps sturdy things up and also running thread rod down from the top of the wall through a plate attached to the joists are two methods used on this type of wall. Is one more preferred than the other? Any other methods I should consider? Total wall height will be in the 73-76 range.
My second question has to do with finishing the walls around the shower. The shower will be attached to the bare studs and there are flanges for this. Do I then drywall over those and seal that edge with caulk? My current thinking is to extend the kicker wall up and out 2-5 inches and drywall the edge/corner to form an appealing finish. Perhaps some sort of special drywall is in order for this type of installation?
quackaddict is offline   Reply With Quote
Old 03-10-2013, 06:38 PM   #2
DIY staff
Rewards Points: 7,174
Will there by one or two loose wing walls?
Old 03-10-2013, 07:17 PM   #3
Rewards Points: 91
One, the other two are framed from ceiling to floor.
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 12:15 PM
Non-Load Bearing Wall Window Framing? ericht Building & Construction 28 01-27-2010 08:38 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
