Framing A Wall For A Shower Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 07:14 PM   #1
Rewards Points: 91
framing a wall for a shower door
guys - i'm building a shower, with one of those glass frameless doors. How do I make sure it has enough support to open/close without falling off? A standard piece of 2"x4", nailed in like a stud where the hinges are expected to be? How about a piece of 4"x4" instead - greater strength and a bit more flexibility on hinge placement?
Any advice on this would be greatly appreciated!
mmhendrie is offline   Reply With Quote
Old 03-24-2009, 08:08 PM   #2
are you sure where its going to be exactly? Then you can double or triple 2X4's or put a piece of 2X6 between tow 2X4's on flat. 4X4 will work but over kill.
II Weeks is offline   Reply With Quote
Old 03-24-2009, 09:16 PM   #3
Rewards Points: 91
isn't two 2x4's the same as doing a 4x4? If so, I think I'd prefer the 4x4 - just, if the hinge goes through the middle of 2 2x4's, it might not get much "bite"? or am I wrong on this?
Old 03-24-2009, 09:17 PM   #4
no, youre right! do it your way. it will be fine
Old 03-24-2009, 09:19 PM   #5
Rewards Points: 91
ok!
I assume I mount the 4x4 as a 2x4 (first time doing this!) - 2 nails on one side, one on the other, 60 degree angle, top and bottom? Does it need any other support, or just framing it into a wall like this be ok?
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
duct work framing kama Carpentry 4 11-15-2008 01:40 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
New exterior french door install in a stucco wall lightninrodman Building & Construction 2 06-30-2007 12:08 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
