Framing Wall...how Straight Do 2x4's Need To Be? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 03:54 PM   #16
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
as already mentioned your plates should be deadly straight although this isnt always an option.. in that case make relief cuts in them to take the tension out of the crown so they can be nailed to the floor or ceiling straight
studs.. no more than a 3/16 crown is fine .. use totally straight studs for making corners, posts and king + jack stud combos for roiugh openings.. . studs that arent perfectly straight are used in the field of a wall (filler studs) or stacked aside to be cut up for cripple studs and sils for r.o's
the theory behind crowning out is so that when cabinets are hung the box wont rock on the wall it just needs to be shimmed into plumb hanging off the wall
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
kwikfishron (12-13-2012)
Old 12-13-2012, 05:55 PM   #17
Rewards Points: 89
As a rule,I always buy Grade 1 lumber from a reputable yard,not the big box stores,cost a little more,saves boku time and headaches.
If you are a DIYer,screwing with crowns and bows shouldn't be something you concern yourself with,your work will also look much better.
spring3100 is offline   Reply With Quote
Old 12-13-2012, 07:14 PM   #18
lol.. paying more to get lumber than at a bigbox...
i get higher grade lumber at the lumber yard and at 20% less than the bigbox stores
Old 12-13-2012, 08:12 PM   #19
Rewards Points: 236
around here, the box stores have put most of the lumber lards out of business.
i hate picking out lumber ! checking 100 boards to get 25 good ones, you can have that.
Fix'n it is offline   Reply With Quote
Old 12-13-2012, 09:37 PM   #20
the main lumber yard was bought out by one big box yet have kept their operations the same. its why rona bought them. the regular big box stores cant get the contractor sales.. kent's has terrible lumber and the prices are pretty much the same.. hd cant handle the volume plus they only have 2 delivery trucks shared between 2 locations
pierceys/ rona has 6 locations and roughly 50 trucks
Old 12-13-2012, 11:44 PM   #21
Rewards Points: 89
I was comparing Grade 1 to grade 2,not big box to a lumber yard
Old 12-14-2012, 08:22 AM   #22
AHH, SPANS!!!
Rewards Points: 1,166
lumber bows to your will not the other way around With long lumber you can make it straight up to a point, get it in the wall and then use a temporary brace if needed to pull/push the crown out and then set it in place by nailing it. if you can tie in enough of the structure as a whole then lumber that is not straight can be straightened. freestanding walls or fill in walls are another matter though and cannot always be straightened as easily...
hand drive is offline   Reply With Quote
Old 12-14-2012, 12:20 PM   #23
I got the wall up and everything turn out great!...
Freakaloin is offline   Reply With Quote
The Following User Says Thank You to Freakaloin For This Useful Post:
bbo (12-14-2012)
Old 12-14-2012, 12:55 PM   #24
bbo
awesome, if you'd like to stop over to practice some drywalling, mudding and taping, I've got an opening !!!
bbo is offline   Reply With Quote
Old 12-14-2012, 11:23 PM   #25
Rewards Points: 968
share some pics!
federer is offline   Reply With Quote
Old 12-14-2012, 11:24 PM   #26
Rewards Points: 968
hi-how do you tell what grade lumber you are buying?
Old 12-15-2012, 05:31 AM   #27
kwikfishron's Avatar
Rewards Points: 772
Lumber (including plywood) has a grade stamp on it.
kwikfishron is online now   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
interior wall framing question ratherbefishing Building & Construction 2 03-20-2011 12:24 AM
Framing basement wall without covering top plate and rim joist dave11 Building & Construction 5 10-30-2009 08:38 PM
Peplacing rotten framing against brick wall minnjh Carpentry 2 07-01-2009 03:21 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
