Framing A Walkout Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 05:03 PM   #1
Framing a walkout basement
Hi,
I am going to be starting to frame my walkout basement. I have framed one basement before but it was not a walkout. About half of the basement is framed and insulated above the ground, concrete slab. I am wondering what I need to do to frame the concrete walls. Any help would be great. Thanks, Chad
Baseballer2534 is offline   Reply With Quote
Old 06-16-2008, 05:19 PM   #2
Jay123's Avatar
We always frame a 2x4 wall with a 1" gap between the concrete and back of new framed wall. We glue and nail (powdered activated gun) the bottom plate to the concrete floor.
J
Jay123 is offline   Reply With Quote
Old 06-16-2008, 05:22 PM   #3
Do I have to run the wall all the way up past the top of the concrete slab? The problem I am having is that the framed wall above the slab is set back? Do I just build a new wall over that? Thanks! Chad
Old 06-16-2008, 05:31 PM   #4
Jay123's Avatar
Here's an illustration of my first post.
J
Framing a walkout basement-new-frame.jpg   Framing a walkout basement-existing-ov.jpg   Framing a walkout basement-new-frame-ov.jpg
Old 06-16-2008, 05:35 PM   #5
Jay123's Avatar
For your pony walls you can frame a new wall all the way to the ceiling for a flat wall...or frame the bottom portion to create a ledge around the room (or 1 wall). We did that recently...
J
Framing a walkout basement-zynko-pre-insulation-155.jpg   Framing a walkout basement-zynko-br-finish.jpg
Old 06-16-2008, 05:38 PM   #6
Jay123's Avatar
Here's another angle of the finish.
J
Old 06-16-2008, 05:48 PM   #7
Thanks! I like the ledge idea, however my ledge starts at about 1 foot, goes to about 4 feet and than goes up to about 6 feet. It may work though. Thanks for all of your help.
Old 06-16-2008, 05:54 PM   #8
Jay123's Avatar
You're welcome. Yeah, if you have a stepped pony wall I would just frame a new wall, floor to ceiling, in front of it.
J
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 03:20 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 10:54 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Walkout Basement Door allworld Building & Construction 1 06-17-2006 12:50 AM
