Old 09-01-2011, 12:10 PM   #1
Question
framing for vinyl wind barrier (See photos)
I want to cover the four sides of a rectangular outdoor pen in clear vinyl “fabric” in some way that makes it quick and easy to remove and replace twice a year. The pen is 15 x 9 feet and is 6 feet high; it’s built of vertical two by four lumber placed three feet apart; there's a horizontal board up top and another at the bottom, around the entire pen. Heavy gauge welded wire is permanently installed with screws and washers on the inside of the pen on all four sides. In the Autumn every year I install clear vinyl shower curtains stretched tight on the outside of the pen’s four walls, and in the Spring I remove them. The vinyl provides a wind barrier during the cold months. Each shower curtain is 6 X 6 feet, so I use eight curtains. But it’s very labor intensive using screws every foot or so all around each of the eight panels of vinyl. (Note: the ceiling is left open to the air for ventilation; no vinyl needed there. A raised roof keeps the rain and snow out.)
Can you suggest a clever way to create an easy-to-remove-and-replace system for the vinyl wind barrier? Some kind of magnetic frame? Some kind of snap-on frame? Some sort of adhesive frame? Some kind of roll-up system?
The system must keep the vinyl snug against the wood to prevent the wind from lifting the vinyl.
The shower curtain liners that I’m currently using cost $8 each, so $64 does the whole pen. I don’t want to have to spend big money on some fancy custom made system. I’m hoping there’s some existing hardware that I can purchase so that I can fabricate a system that will work. Vinyl material from a fabric store is affordable (about $10/yard) and is 52 inches wide. Not quite wide enough to wrap the pen horizontally.
I’d prefer not to have to spend hours installing metal grommets. If there were some snap-on framing available, that might be ideal. Especially if the frame could come apart for storage during the summer, and I could just fold up the vinyl and put it away until the cold weather set in again.
The vinyl has to be CLEAR to allow maximum daylight to get into the pen. (My three hens need daylight to keep laying eggs.)
Carolyn252 is offline   Reply With Quote
Old 09-01-2011, 05:17 PM   #2
Perhaps these things with some elastic cord zig-zagged around screws in the framing (like shoe laces are used to connect one side of shoe last to the other)?
http://www.amazon.com/Tarp-Grabber-I...4911754&sr=8-1
bob22 is offline   Reply With Quote
Old 09-02-2011, 05:50 PM   #3
Make 16 panels that are 3'x6'. just use 1x3 or 1x4 for the frame and then you could affix the vinyl permanently to the frame with screen moulding.. then attach frame to your uprights with a screw in each corner. Cost would be under $175 and would pay for itself in 3 years. You could paint the frames to match. Might take 30 min. to put up and take down.
josall is offline   Reply With Quote
Tags
chicken coop, framing systems, outdoor run
Moisture barrier for framing pennshaq Remodeling 0 07-02-2010 08:45 AM
Basement Framing vapor barrier emccarthy2 Building & Construction 2 03-24-2010 07:35 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
