Framing The Ventialtion In A Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 03:00 AM   #1
Framing the ventialtion in a basement
I am framing up the basement and have some ventilation that hangs down lower than the ceiling. How do I frame that to hang drywall to "box it in"? Any pictures would be great.
jacads is offline   Reply With Quote
Old 08-16-2009, 05:58 AM   #2
mark942 is offline   Reply With Quote
Old 08-16-2009, 12:02 PM   #3
are those 2x4s?
Old 08-16-2009, 01:00 PM   #4
Registered User
Rewards Points: 5,520
You can use 2x4 or 2x2, for short spans. Some use solid wood boards for the horizontals, some build ladders, then hang the assembly from the floor above as a unit. Some use a pair of left-over I-joists, if deep enough. Be sure to install fire-blocking above the unit when running perpendicular to the joists (as in the picture -top right side, between the joists) to stop any fire from spreading more than 100 sq.ft. If no blocks present, fire in the enclosed chase will spread to the whole floor system in minutes, popping up all over the house. And then your homeowners insurance would not cover the loss because the framing was not to code. This on fire blocking from kctermite: How to fireblock framing
Be safe, G
Framing up a wall in the basement hankscorpio Building & Construction 7 11-28-2012 06:53 PM
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 03:20 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 10:54 AM
