Framing Treated Lumber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 01:11 PM   #1
Can you frame interior walls with treated lumber? Is it okay to install treated lumber as floor joist in your home?
Sbagwell647 is offline   Reply With Quote
Old 03-19-2011, 01:17 PM   #2
liscenced electrician
Rewards Points: 538
ive always wondered the same thing. My thoughts are that one or two here and there is fine, but you probably wouldn't want to frame your entire house with it because it might put chemicals into your house. Maybe im just overthinking it though
jimmy21 is offline   Reply With Quote
Old 03-19-2011, 10:18 PM   #3
remodeling pro
Unless you can purchase WAY AHEAD OF TIME(6 mos or more) and allow to dry out; or have access to KDAT material, it contains way too much moisture for this.
Why do you need pt for interior walls?
troubleseeker is offline   Reply With Quote
Old 03-20-2011, 01:34 AM   #4
Registered User
Rewards Points: 5,216
Check with your local Building Departments.
Gary
Old 03-20-2011, 08:20 AM   #5
DIY staff
Rewards Points: 7,174
Gary
They are not allowed in my area-----Why would you choose treated.which is prone to warping,twisting and shrinking? Very expensive fasteners must also be used.
Just wondering.-----Mike----
Old 03-20-2011, 11:54 AM   #6
Framing Contractor
Why? Treated lumber s for exterior use.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-14-2011, 11:44 PM   #7
Glad I read this topic. Didn't realize that treated lumber would do that. I just thought that it would be less prone to decay if I used it for floor joists. I mentioned to two sales guys at Lowes that I was thinking about putting treated 2X10 under my kitchen floor up against the floor joists there because the people that built the house used 2X8s on a 16 foot span and I wanted to reinforce the floor. Its a crawl space and they put ladder like structures all over the place on the ground-built before footers. Neither one said a word about the possibility of shrinkage. Thanks Glad I hadn't gotten started on that project yet.
tayna is offline   Reply With Quote
Old 07-15-2011, 12:04 AM   #8
plus the chemicals in the lumber , and i dont go to lowes for advice on anything , its not like some 18yr old kid is going to now anything or a partime person , all they now is what a computer tells them at least thats how it is around my area
fulton 22175 is offline   Reply With Quote
Framing with treated lumber posts That70sHouse Building & Construction 15 02-14-2011 09:40 AM
Non treated lumber - base plates... dj1963 Building & Construction 5 06-24-2010 09:42 PM
Where to buy heat treated Plywood or OSB and lumber? Spud General DIY Discussions 5 10-21-2009 10:49 PM
removing treated lumber edging pacifier1er Landscaping & Lawn Care 3 07-02-2008 01:08 PM
Framing lumber very hard?? handyflyer Remodeling 2 04-15-2007 11:44 PM
