Framing Tee Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2014, 05:59 PM   #1
Rewards Points: 137
Framing tee wall
Do I need any additional studs at the intersection of these walls? As the pictures show (hopefully) I added a stud behind the stud of the left wall for sheet rock attachment. I'll add another to the other side. There is a stud perpendicular to the cement wall that you can't see. Anything else needed? Thanks
Jack E is offline   Reply With Quote
Old 02-24-2014, 06:03 PM   #2
Rewards Points: 109
Looks fine to me. Hang the drywall on left first so you can fully screw into the wood with out having to angle screw. The right has a lot of wood to bite so no issues there.
Olcrazy1 is offline   Reply With Quote
The Following User Says Thank You to Olcrazy1 For This Useful Post:
Jack E (02-24-2014)
Old 02-24-2014, 07:46 PM   #3
landfillwizard's Avatar
Rewards Points: 516
Do you have your drywall on the ceiling? Or is that ceiling going to be finished? If you are going to add more dry wall to the ceiling, then I would put nailers around the top plate.
landfillwizard is offline   Reply With Quote
Old 02-24-2014, 07:54 PM   #4
Rewards Points: 137
There's drywall on the ceiling, no texture, taped joints showing. I'll give it some attention before painting.
Question regarding likely framing behind fireplace on exterior wall JKeefe Building & Construction 11 01-07-2014 01:39 PM
Interior Wall to Exterior Wall Framing 123pugsy Building & Construction 9 08-31-2013 10:47 AM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 12:15 PM
Non-Load Bearing Wall Window Framing? ericht Building & Construction 28 01-27-2010 08:38 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 12:03 AM
