Old 01-31-2011, 07:24 PM   #1
framing a steel post
how do i frame a wall with a steel post in the wall?
randy isham is offline   Reply With Quote
Old 01-31-2011, 07:25 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Really can't tell you without pictures showing the wall in question. If you really want to hide it, and it is up against the foundation, use either 2x6 or 2x8 on that wall, same if it is in the middle of the room where a wall will be.
Old 01-31-2011, 08:20 PM   #3
make the wall in two sections and butt them up to the post. Most basement posts are 3 1/2" diameter. If it's bigger, fir out one side or use 2x6 studs
mrgins is offline   Reply With Quote
Old 01-31-2011, 08:36 PM   #4
Steeler99's Avatar
is it a tube or a pipe? Is it a kitchen wall? I only ask because if you're mounting cabinets to it, it would be better to attach your king studs to the column if possible. Mrgins is right, just attach to it if possible. Otherwise, don't attach to it, but be sure the wall is secure at the top and bottom...and span your drywall over it, centering the post on the drywall. Then finish the rest of the drywall from the center piece. That's what I'd do.
Steeler99 is offline   Reply With Quote
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 02:50 PM
