Framing A Standard 60" Bathtub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 05:02 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Framing a standard 60" bathtub
I need to frame the valve end of a bathtub I just installed. It was framed, but I need to rearrange the studs on the valve end to the optimal locations. Whats the best spacing for the valve assy? is there a standard? Thanks!
MikeKy55 is offline   Reply With Quote
Old 01-12-2011, 05:12 PM   #2
KemoSabe
loneframer's Avatar
In general, most plumbers I know want a minimum of 12". I typically use a standard 16" center though. You'll want to center the width on the tub drain centerline.
loneframer is offline   Reply With Quote
Old 01-12-2011, 06:03 PM   #3
MikeKy55's Avatar
Rewards Points: 254
Thats what I needed, thank you!
Leaky American Standard bathtub faucet t1r2u3s4t Plumbing 9 01-13-2015 04:40 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Framing for bathtub safety bar Randell Tarin Building & Construction 4 01-27-2008 08:06 AM
Code - Framing Under 2nd Floor Bathtub austinbirdman Building & Construction 2 03-04-2007 02:14 PM
