Framing Spacing On Duct Soffit Box - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 11:44 AM   #1
framing spacing on duct soffit box
I know that for hanging 1/2" gyproc on ceilings the members should be 16"oc, but I'm wondering if I can get away with 24"oc for framing in ductwork where the box will be about 5' wide. Will the gyproc sag? I plan to finish this part of my project tonight, so any thoughts would be great.
gdoucette is offline   Reply With Quote
Old 06-11-2010, 12:02 PM   #2
firehawkmph's Avatar
Rewards Points: 1,864
Use 5/8" drywall for 24" spacing, the 1/2" will eventually sag.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-11-2010, 10:15 PM   #3
Registered User
Rewards Points: 5,492
Read fast, then: http://www.gypsum.org/pdf/GA-216-07.pdf
Be safe, Gary
Flex Duct in Soffit HooKooDooKu HVAC 2 01-18-2010 05:48 PM
Soffit and Ceiling Framing stevex Building & Construction 3 12-28-2009 03:49 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
duct work framing kama Carpentry 4 11-15-2008 12:40 PM
Framing a Wall with a Soffit on Top sethr Building & Construction 2 05-21-2007 08:14 AM
