-   -   Framing on a slab floor (http://www.diychatroom.com/f19/framing-slab-floor-26382/)
tripower 09-06-2008 03:22 PM
I am framing a non-structural wall in my bathroom. It has a slab floor. I know that I need to use PT lumber for the toe board, do i need to also use PT lumber for the rest of the framing? If not do I need another toe board using non-PT lumber on top of the PT toe board? What kind of masonry nails can I use to attach the PT lumber to the slab? The only ones I saw said not to use them in PT lumber?
AtlanticWBConst. 09-06-2008 03:58 PM
Originally Posted by tripower (Post 155651)
... do i need to also use PT lumber for the rest of the framing?
No
Yes, you can use KD grade lumber. Just be aware that "bright" nails (untreated) will react and corode in P.T. lumber. Because of this, I prefer to use galvanized framing gun nails all around for Basement framing.
We use a .22 caliber pnuematic Nail fastener for that, and use the gray coated nails.
Joe Carola 09-06-2008 04:00 PM
All you need is pt for the shoe/sole plate (just other names)toe board, nothing else.
Ask for ACQ rated cut nails at real lumberyard, not HD or Loews.. I use them all the time.
