Framing A Shower Stall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 06:26 PM   #1
framing a shower stall
When framing a wall next to a shower stall, should the wall be flush with the edge of the shower base
or should there be some distance so the shower base it tucked in?
I haven't decided if I am going to use a shower curtain or a door.
Would this make a difference?
wall to be flush with shower base (keeping room for drywall and possibly tile)
wall beyond the shower base
pros or cons for both methods would be helpful.
Thanks,
DK
n2learning is offline   Reply With Quote
Old 04-05-2011, 06:50 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
....whats goin on the walls?
12penny is offline   Reply With Quote
Old 04-05-2011, 11:05 PM   #3
Tile over cement board in the shower enclosure.
I may tile half way up the wall on the rest of the walls in the bathroom.
Old 04-06-2011, 07:48 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
Build it long. Easier to get backer, drywall and corner bead on it. You may be able to make it long enough to tile to the corner with full tiles. Depends on how big your tiles are.
The Following User Says Thank You to 12penny For This Useful Post:
Willie T (04-06-2011)
Old 04-06-2011, 09:00 AM   #5
Old School
Willie T's Avatar
Looks much nicer longer. Holding it short makes it look like you made a mistake when ordering a shower base to fit a pre-existing wall... even if you happen to hit the length just right.
Willie T
Old 04-06-2011, 09:26 AM   #6
I made such a rookie mistake.
I can only go out about an inch to keep within the required distance from the center of the toilet flange to the wall. I believe it's 15 inches.
Thanks for the input.
DK
Old 04-06-2011, 12:07 PM   #7
Not so new
12penny's Avatar
Rewards Points: 520
...no big deal. Doesnt look like anythings framed up yet. Can you move the base back some or are you as far as you can go?
Old 04-06-2011, 10:05 PM   #8
The shower drain is already cemented in so I can't move the base back. (FYI: the shower pan has not been set)
Because I didn't do the best measuring, do I need to add furring strips to the 2x4's so the cement board will be snug and tight?
It might be better if I used 2x6's on this wall instead of 2x4's. There will still be a gap but not as much if I stay with 2x4s.
Is there a different option other than adding furring strips?
On another note, I originally had this measured for a 28" door, however I just read that a 30" door is the required minimum for a basement bathroom.
How much room should I allow for the door frame if I am going to put in a 30" door?
I do appreciate the help. This my first "big" DIY project.
Old 04-06-2011, 11:47 PM   #9
firehawkmph's Avatar
Rewards Points: 1,798
N2,
32" on the rough opening width for your door, 2" + the door width. 82 1/2" for the height.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-07-2011, 07:53 AM   #10
Not so new
12penny's Avatar
Rewards Points: 520
can that framing be removed? Doesnt look fastened to the floor.
Old 04-07-2011, 08:34 AM   #11
The framing has not been fastened. Will be putting up the top plates soon.
It's hard to tell from the pics, but concrete had to be poured to have an even bathroom floor. I live in an old home that has a dip in the basement floor.
I just assumed the sole plates will go on the edge of the perimeter. Once drywall is put up on the outside of the walls I will add some molding to the bottom so the new concrete isn't visible.
*Thanks for the tip on the door frame*
Shower stall installation mforeman1 Flooring 1 04-06-2011 08:39 AM
Fiberglass shower stall scarrylarry Painting 2 02-24-2011 07:27 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 10:00 AM
Advice about framing for a shower stall Tooncie Building & Construction 1 08-27-2010 09:54 PM
shower stall with hole (cold air coming in) mcvane Plumbing 1 02-08-2009 11:41 PM
