-   -   Framing a round wall? (http://www.diychatroom.com/f19/framing-round-wall-28363/)
bendair Dundat 04-18-2005 09:11 AM
Does anyone know how to frame round wall? I haven't found any books that show how to do this. I know it can be done because I found a book that shows how to drywall a round wall but not how to frame one. Does anyone have any pointers on how to do this? Thanks!
bendair Dundat 04-25-2005 03:58 PM
Am I in the right place with this question? If so, would someone please direct me. Thanks!
MgMopar 09-10-2005 09:52 AM
The simplest way to achieve a curve on a wall (not a support wall) is to lay out the curve on thick plywood and cut it out two identical curves as wide as the studs to be used as top and bottom plates. Mark the stud centers on the top and bottom then locate positions and put in place. (plywood does not meet code for support walls but for a decorative wall it should be ok in most areas.) I have seen it done in this matter in an office remodel that pasted local inspections. If applying for a permit and local codes have issue you should be able to cut 4 curves from 7/8 and glue and nail the pairs together to make suitable top and sill plates.
bendair Dundat 09-12-2005 11:23 AM
Thanks for the reply. This is exactly the answer I was looking for.
