Framing In Roof Over Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2007, 09:17 PM   #1
Rewards Points: 266
framing in roof over addition
I have gotten a lot of great advice from diychat and thought this would be a no brainer for seasoned framers/roofers.
The original house is only 16'6" wide, there was an addition on the backside with a flatroof. the addition is 9'1" I want to slope the roof over the addition.
my question is what size lumber should I use to fram the rafters? Would 2x6 suffice or should I go with 2x8"
here's what I got:
so on the front side of the house I have 8'3" to ridge with a 8/12 pitch
on the backside 9'1" was added so from the ridge to the outer rear wall is now 17'4"
I know the pitch will be shallower on the backside roughly about a 5/12.
The original trusses are the true 2x4" sized I know I need to use bigger dimmensional lumber with todays lumber.
I roughly calculated the length of the new rafter to be 19'4"
My question is will 2x6 be beefy enough using todays lumber (5 1/4") or should I pay the lil extra for overkill and go with 2x8"
vbrep_register("46170")
What have I done is offline   Reply With Quote
Old 05-25-2007, 07:50 PM   #2
Rewards Points: 77
Your lumber yard should have span tables for the species and grade of the lumber they carry and give you the dimension you need for that span. Or do a "Google" for lumber span tables and you'll be able to do it yourself.
Zero Punch is offline   Reply With Quote
Considering Room Addition & Roof Change pkthomas_ar Building & Construction 4 05-02-2007 06:41 PM
Reactions to Timeline for Framing Addition austinbirdman Building & Construction 6 01-19-2007 01:49 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
second floor addition without removing original roof coralhead1 Building & Construction 8 10-06-2006 05:56 AM
Need help with framing roof for sunroom diehard_1955 Carpentry 1 04-27-2005 10:24 PM
