Framing Question Adding Door To Stud Wall With Cross Bracing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 12:38 AM   #16
Originally Posted by cortell View Post
Is it possible the T1-11 is not original? I would expect 5/8" T1-11 to provide enough shear strength. My theory is that the let-in bracing was at one point the only thing making that wall a shear wall. Then the siding was replaced with T1-11, which made the let-in bracing obsolete and relatively pointless (much like, say, a casing nail where there's already a common nail). Of course this is just a guess. What concerns me is the proximity of the proposed opening to the end of the wall. The ends are critical areas in shear walls. You really should consult with a professional in your area for a thorough evaluation and recommendation.
The T1-11 is original on the exterior.
cakenoodle is offline   Reply With Quote
Old 06-05-2012, 12:40 AM   #17
Originally Posted by AndyGump View Post
What is the purpose behind the 4x6 beams so close to the floor?
Andy.
I am not exactly sure but my first thought was that this was a carport before I added the garage door and that the raised beams would make washing the carport out with water would be my only guess.
Old 06-05-2012, 08:42 AM   #18
Rewards Points: 502
Exactly; if the opening is to be near the end of the wall, no amount of extra bracing or sheathing will compensate and maintain it as a shear wall. This is why I said in my original post that both the size and position of the opening are important factors.
tony.g is offline   Reply With Quote
Old 06-05-2012, 11:24 PM   #19
Registered User
Rewards Points: 526
The elevated side framing suggests "letting the water out" as said, at least to me. When I visited there in '66, it would drop 1/2" of water in less than 10 minutes time..... the flash flood would jet across the streets into the open shops and out because the walls had gaps next to the ground for that reason. I suspect the let-in was for the framers after framing the wall on the slab without siding, holding it square to be plumb after lifting/standing it in place.
The T1-11 is structural, stand-alone without bracing, let-ins, or otherwise. Very popular around here in the early '70's when I started framing. Count the number of face plugs- 6 or less, I'm guessing if it's older material; http://www.joneswholesale.com/produc...cts.htm#guides
You are in 105mph wind zone. I am more concerned that you are in a seismic zone where wall/roof anchorage to the slab is critical- and existing is inadequate, consult your local AHJ; http://publicecodes.citation.com/ico...001_par004.htm
Be sure to add bearing directly under the 4x16 beam to slab.
Gary
Question regarding framing a basement wall James0816 Building & Construction 0 05-28-2010 09:41 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 07:41 PM
Door Framing Question biggidybankston Carpentry 4 12-10-2009 12:26 PM
Simple question on 16" O.C. framing TitaniumVT Building & Construction 10 11-27-2009 06:51 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
