Framing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 09:59 PM   #1
In a little over my head
Rewards Points: 706
Framing question
The weather is supposed to be good this weekend, so I should be framing my addition. It's 6'6" x 13 exterior dimensions, with the long wall parallel to the house. I'm living in the house, so the plan is to take down the siding, then cut out just enough blackboard sheathing to attach the new wall to the existing walls. After it's dried in, I'll take down the rest of the existing sheathing, replace with sheet rock. I'm thinking I'll put up the two short walls, then the long one. The questions are:
Does it matter if (a) the short walls reach the corner and the long wall butts into them, or (b) the short walls stop 3.5" short, and the long wall reaches the corner?
The room is only 6' wide. That's gonna make it tough to build the 12' wall laying down. And I don't have many helpers. Should I try to build it flat, in 6' sections, or just build it stick by stick, upright?
Or am I completely missing the easy way to do it?
Thanx!
Mike
ratherbefishing is offline   Reply With Quote
Old 03-10-2011, 11:36 PM   #2
Registered User
Rewards Points: 5,492
If 2x4, I'd frame the side walls first and butt the long wall (lighter w/o the 4 corner studs) to them, after framing them on the driveway. Sheath them after standing, plumbing, bracing, fastening down to floor, slab. 2x6 long wall may be too heavy for one man, could break at a stud on layout from whichever end. Double top plate will lap so corners are not critical, which wall abuts...
Gary
Old 03-11-2011, 01:08 AM   #3
your actually thinking the right way,build the 6 foot sides all the way out and butt the long wall into them,i would build the long wall in place after the 6 footers were built,braced and plumbed.dont forget to leave top plate on 6foot walls cut back 3-1/2 to receive long wall the rest is easy.
shark722 is offline   Reply With Quote
Old 03-12-2011, 06:45 PM   #4
Rewards Points: 706
Well, I got lucky today. I pulled the siding off, and cut two slots in the blackboard to attach the new walls. I was expecting to have to sister a few studs, to get a place to attach sheetrock. It turns out that the corner and the ridge support are not 2x4's as I expected, but 4x6's! That makes it easy. And notching the eave soffit and fascia gave me plenty of height to get the new walls attached. I've got the first wall laying flat and ready to lift tomorrow. The second one should be easy. Then, I'll either start on the long wall, or go fishing for a couple of hours.
Mike
Old 03-13-2011, 09:03 PM   #5
Rewards Points: 706
Two walls up! Square and plumb!
Above grade framing and a few framing question jreed Building & Construction 6 01-16-2010 10:56 AM
Framing Question flati Building & Construction 10 01-12-2010 10:24 AM
Balloon Framing Question zetti1102 Building & Construction 2 09-30-2009 09:50 PM
Newbie with a framing question. 737Pilot Building & Construction 19 03-21-2008 06:53 PM
stupid framing question amakarevic Building & Construction 12 02-23-2008 03:29 PM
