Framing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 02:23 PM   #1
framing question
Need help with header size in a ten foot opening and what inch bearing will b ok?
elares1780 is offline   Reply With Quote
Old 04-03-2014, 03:36 PM   #2
kwikfishron's Avatar
Rewards Points: 1,008
You're going to need to provide some more details than that. Posting a drawing or pictures would help.
kwikfishron is online now   Reply With Quote
Old 04-03-2014, 03:41 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
depends on the vertical and horizontal loads it must support, no way to know with the information you've provided.
as kwik said a drawing and/or photos would help
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
elares1780 (04-03-2014)
Old 04-03-2014, 03:53 PM   #4
Ok will attach pix
Old 04-03-2014, 05:20 PM   #5
Maryland
http://publicecodes.cyberregs.com/ic...2_5_par019.htm
TABLE R502.5(1)*GIRDER SPANS AND HEADER SPANS FOR EXTERIOR BEARING WALLS (Maximum spans for Douglas fir-larch, hem-fir, southern pine and spruce-pine-firb and required number of jack studs)*
That table provides some prescriptive guidance. An onsite visit from an engineer would be advised for any scenario that doesn't fit into that table.
Pittsville is offline   Reply With Quote
The Following User Says Thank You to Pittsville For This Useful Post:
Old 04-03-2014, 06:57 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
well once you have a opening thats over 7'6" its no longer a header it now has to be a beam either 3ply or engineered.. you will need atleast 3" bearing ie. double jack studs that carry the loads down to the foundation wall
woodworkbykirk is online now   Reply With Quote
Old 04-03-2014, 06:59 PM   #7
Having trouble proving an existing header without demo sugg?
Old 04-03-2014, 07:07 PM   #8
GBrackins's Avatar
the only I know to confirm the size of the beam is to expose the entire beam.
Gary
Old 04-03-2014, 07:29 PM   #9
The house is stacked balloon framed and i dont see any support
Shed Roof Fascia and Framing Question crhage Building & Construction 3 06-22-2011 06:54 AM
Above grade framing and a few framing question jreed Building & Construction 6 01-16-2010 10:56 AM
Framing Question flati Building & Construction 10 01-12-2010 10:24 AM
Balloon Framing Question zetti1102 Building & Construction 2 09-30-2009 09:50 PM
stupid framing question amakarevic Building & Construction 12 02-23-2008 03:29 PM
