framing question
Actually, your only short about 1/2". Your 32" door will most likely measure out to about 33 1/2".
Is your 39" hallway measurement including drywall?
Since this is a hallway....I personally would prefer the larger door....30" is getting pretty narrow.
Hopefully the experts will chime in....but if was me...I would take those jack studs and shave about 1/4" off each one with a table saw.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
