Framing Over Cinder Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 11:52 AM   #1
It's always something
Rewards Points: 150
Framing over cinder block
I've decided I want to put up framing over the cinderblock walls in my garage and then drywall. In the picture below, is it really that simple? What steps should I take to ensure I'm doing it correctly?
The job looks straight-forward but in my garage, there is already a finished ceiling and I'm not so sure what I need to do in order to attach a 2x4 up there since I now have no exposed joists. Do I need to take the ceiling off first or what?
According to the image, the frame does not get attached to the cinder block, this is true?
Thanks!
SingleGuy is offline   Reply With Quote
Old 04-05-2012, 12:00 PM   #2
Rewards Points: 1,092
Myself, I'd use more foam, furring strips anchored to the wall, and skip the fiberglass. PT bottom plate, as shown, and tape the seams of the rigid foam.
Old 04-05-2012, 12:07 PM   #3
Rewards Points: 150
Thanks for the reply. What does 'PT' mean? You mention furring strips. Are you saying you'd attach strips directly to the block? I was trying to not do that so I don't risk weakening the block wall and same me time as well. What advantage do furring strips have?
I should mention I plan to hang things from the wall once I'm complete ( that's the whole reason to do this ). Will the strips give me more strength to hold stuff?
Old 04-05-2012, 12:18 PM   #4
PT= pressure treated. I can not imagine a few anchoring screws reducing the strength of the blocks. You'll only have a few per furring strip. I'm not a concrete guy, so maybe one of the folks more experienced w/ that will reply. Whether or not they would hold your shelving depends on what is on the shelving, of course. I am sure fastener web sites have data on what size, etc, for what weight.
The Following 2 Users Say Thank You to jklingel For This Useful Post:
concretemasonry (04-05-2012), SingleGuy (04-05-2012)
Old 04-05-2012, 12:18 PM   #5
Rewards Points: 3,130
I wouldn't use furring strips, especially if you are going to hang things from the wall. Also, if you use them, your walls will be too shallow for electrical boxes if you want to add outlets or switches.
"PT" means pressure treated lumber. Wood in direct contact with masonry must be pressure treated so it doesn't rot.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 04-05-2012, 12:28 PM   #6
Rewards Points: 150
Ah.. 'pressure treated'... got it Good to know about the treated lumber.
From that image, it looks like NONE of the studs are attached to the block. That makes me wonder how it will really hold anything.
Yeah, I plan to put electrical boxes in the new walls too. The items I plan to hang range from my bicycles to a wheel barrow, ladder, etc. I have no way to hang them now without having to punch holes in the block with TapCons and short pieces of wood.
What would be the best approach to tackle the finished ceiling? What other things must I do to make sure this is done properly?
Old 04-05-2012, 12:44 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The wood should never come into contact with the block. Use pressure treated lumber for the bottom plate and regular lumber for top plate and studs.build your frame on the floor then put it in place about 1"off the wall.secure bottom plate to the floor with ramset and top plate to the joists. No need to make the whole frame out of PT lumber.if you put the wood againest the wall it will pull the moisture out of the block.
No need to remove the ceiling,once the frame is rocked it will look finished.
Look at the pic,see the bottom plate looks green?
PT lumber.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Old 04-05-2012, 02:39 PM   #8
Rewards Points: 150
That ramset looks pretty nice. Is there another option to attach the bottom plate though? That looks a little expensive and this is only a two-wall project
Is the blue foam in the picture for a vapor barrier or insulation ( or both? )? Is that a required component if the other side of the wall has no dirt on it? Speaking of which, should I coat the cinder blocks with some sort of sealant prior to putting the studs up?
Old 04-05-2012, 02:44 PM   #9
Rewards Points: 150
Something else I'd like to confirm here... I've read a little about how far the drywall should be up and away from the floor. If I'm not mistaken, 1/2" is the minimum gap between dryall/floor right? Looks like that in the picture too. I suppose a base board will cover that gap up?
Old 04-05-2012, 03:50 PM   #10
rditz's Avatar
you can use a hammer drill and fasten the bottom plate with Tap-Cons. they are special masonry screws that will secure the wall to the floor.
the rigid foam will act as both a vapour barrier and insulation, that is why you want to tape the seams.. you can buy it in different R- values, so depending on the batt insulation you are using and the overall desired R- value you are trying to achieve, will determine the thickness of the rigid foam. you may consider using some construction adhesive to glue the rigid foam to the block wall and then build your stud wall and press to the foam.
i would also use a foam gasket under your PT bottom plate.
rod
you do not need to coat the block at all
rditz is offline   Reply With Quote
The Following User Says Thank You to rditz For This Useful Post:
Old 04-05-2012, 06:56 PM   #11
Rewards Points: 150
Thanks Rod. I'm going to price the materials tomorrow.
Old 04-05-2012, 08:18 PM   #12
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
That's correct.
When you go,look at the manual ramset. You use a hammer to actuate it.
With the tool,#4 loads and 3" nails it will cost you around $30. Quicker then drilling holes not to mention you will need a hammer drill and the tapcon bits are not really practical for concrete plus you will need to drill holes at least 3 1/2" deep for the tapcon.
Old 04-05-2012, 09:04 PM   #13
cortell's Avatar
Rewards Points: 504
Technically speaking, it's unlikely you have actual "cinder" blocks, BTW. You probably have concrete blocks. They looks the same but have very different density. Cinder blocks are made of ash are thus considerably lighter and less likely to be used to, say, hold up a house. This has no bearing on your question, but I couldn't help throw in that bit of info.
cortell is offline   Reply With Quote
The Following User Says Thank You to cortell For This Useful Post:
Old 04-05-2012, 09:34 PM   #14
Rewards Points: 150
Originally Posted by sublime2 View Post
That's correct.
I'll certainly check that out. That would be cheaper than all the TapCons I'd need too
Old 04-05-2012, 09:36 PM   #15
Rewards Points: 150
I didn't know that. My grandpa called them that so growing up that's what I did thanks
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 10:48 AM
Cinder Block Basement Remodel raxtman Building & Construction 7 07-16-2010 01:37 PM
Wire through cinder block Red Squirrel Electrical 9 07-04-2010 04:45 PM
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 07:48 AM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-08-2009 11:49 PM
