Framing Opening Through Roof... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-03-2007, 11:41 AM   #1
MLO
Framing opening through roof...
In my craftsman style home the plans call for an open "garden window" in the roof/overhang, that is 7'x6' over a large exterior planting area. This is in front of the home over a deep inset created by the wall/porch design and is intended to let weather through as well as light.
This "garden window/opening" (correct terminolgy?) is to have exposed rafters through it for asthetic/architectual purposes.
I'm trying to find some information on the best way to deal with the flashing and water proofing of this opening and it's exposed rafters. I'm in the northwest and are using good DF timbers. This is the weather side of the home and Laminated shingles will be used.
My intention's were to use large drip flashings around the periphery and possiblt try to incorporate a cap of some-sort over the exposed rafters. Not sure, maybe the cap is a bad idea and will only trap/ hold moisture.
Can anyone elaborate or offer some links? TIA
MLO is offline   Reply With Quote
Old 11-06-2007, 04:50 PM   #2
Rewards Points: 5,336
Do you have plans? I can't visualize what's happening.
Ron
Old 11-07-2007, 11:25 AM   #3
MLO
The "garden window" is merely an opening like you would put a skylight onto, only there is no skylight and the rafters are left intact and exposed.
In my case the opening is 7 feet wide and 6 feet tall and is located in the front porch overhang (roof) above where a planting area will be located.
Hope this makes sense, I'm very IT challenged.
TIA
Old 11-07-2007, 10:50 PM   #4
I got it now. I see perimeter flashing (copper)kicked out at the bottom to keep the water off the edges as much as you can anyway. This way the sheathing is protected. Everything else would be au natural. Treat the rest of the wood it as though it were outside, which it is. I have no idea about the woods longevity in this situation, but diligence in maintaince will be required.
Ron
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
Framing Attic Walls but Roof Has SAG! luckestryke Building & Construction 1 04-27-2006 09:40 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 11:50 AM
Need help with framing roof for sunroom diehard_1955 Carpentry 1 04-27-2005 11:24 PM
