Framing Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 11:07 PM   #1
Rewards Points: 225
framing opening
Have a 2"x 4" 16" on center exterior wall 8' high double top plate and single bottom plate. On top of the wall are the ceiling joists and roof rafters for the attic. The 2"x 4" wall sits on a 1"x 4" floor board. The flooring in the rest of the area has been replaced with 3/4" plywood. The exterior wall sits on top of 2"x 8" flooring joists which is on a 2"x 4" wall. Want to frame an approx 36" wide opening 5' high. The opening will not go to the outside for a door but for a recess in the wall. Do the vertical studs to support the ends of the header need to line up with the 2"x 8" floor joists or can they be on top of the 1"x 4" floor board. Thanks.
gt1935 is offline   Reply With Quote
Old 11-20-2012, 11:12 PM   #2
Rewards Points: 12,808
They just sit on top of the subflooring.
Old 11-20-2012, 11:32 PM   #3
Rewards Points: 225
The studs can sit on top of the floor but do they need to be in line with the 2" x 8" joists. Thanks.
Old 11-20-2012, 11:35 PM   #4
No. your only talking about a small opening so there is very little load being transfured.
Framing the spline for a shower door miamicuse Kitchen & Bath Remodeling 6 04-20-2012 06:52 AM
Framing question, basement/first floor remodel enoll Remodeling 0 02-22-2012 01:01 PM
creating an opening bearing or not? Wiscbldr Building & Construction 2 11-01-2010 03:32 PM
Replacement Windows Smaller Than Rough Opening stubits Remodeling 1 08-25-2010 07:19 AM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 06:53 PM
