Framing New Basement Walls Around Exisiting Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 03:43 PM   #1
framing new basement walls around exisiting window
I'm about to start renovating my basement, I am stuck on framing around the basement window as you see in the picture below, some insight would be great.
framing new basement walls around exisiting window-67264_1308987504614_1828386013_590593_83118_n.jpg
mcbagel is offline   Reply With Quote
Old 10-15-2010, 04:09 PM   #2
steveel's Avatar
If you're in a place that requires a permit for the basement job, have you talked over your plans so far with the inspectors and what did they say regarding your design for the wall leading up to the window?
steveel is offline   Reply With Quote
Old 10-16-2010, 06:06 PM   #3
Rewards Points: 1,910
Just leave the rough opening the same size as the concrete opening.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Replacing a 20" x 32" basement window Fox Remodeling 2 06-12-2010 12:19 PM
Basement Framing Issues Prep for Drywall golddog Remodeling 8 01-15-2010 06:40 AM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 09:33 AM
Need Help Framing a Window johnpma Carpentry 10 06-11-2009 10:42 AM
