Framing Nailer Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 07:43 PM   #1
framing nailer question
This may sound like a dumb question but it seems like when I watch DIY network and I see people using nail guns I never hear the compressor running. When I use my nailer it seems like it always running. Is this normal?
mikem201 is offline   Reply With Quote
Old 03-05-2013, 07:49 PM   #2
Rewards Points: 13,250
There just using longer air lines so it's not inturupting the show or using guns like a Pasload that does not need a compressor.
You may just be using a smaller compressor or one that has a small tank so it has to run more to keep up.
Old 03-05-2013, 07:51 PM   #3
Ok, so you can't turn the compressor off after a while and still use the nailer?
Old 03-05-2013, 07:56 PM   #4
Depends on how big a tank you have, the tank stores the air.
With a small tank your only going to get a few shots off before there not going all the way in.
Old 03-05-2013, 10:03 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
like joe said they probably have a long air line to keep the compressor away from where their working, we typically do this sort of thing by running a 1/2 " line to feed our hoses that the guns are hooked up to.. right now we have a rol-air 12 gallon in the basement of hte house were siding with cedar shingles. we never hear hte compressor during the day
woodworkbykirk is online now   Reply With Quote
Old 03-05-2013, 10:29 PM   #6
Roofmaster
Rewards Points: 2,172
Paslode makes Pneumatic Guns as well as Gas Actuated. I have the F350S Pneumatic Framing Nailer. Outstanding tool, and light weight. They do use gas actuated tools on most of those shows though. They also do most things wrong, which drives me nuts, so my wife loves them.
Old 03-06-2013, 06:50 AM   #7
Rewards Points: 1,016
I was watching one show and they commented to eliminate the noise they were using guns (like a Pasload) that does not need a compressor.
____________
Vince
Old 03-06-2013, 11:07 AM   #8
it depends on the show. if its brian baumler, or mike holmes trust me they know what their doing they wouldnt have high end companies if they didnt know. but shows like 10 grand in your hand are absolute joke
Old 03-06-2013, 11:41 AM   #9
I tryed watching some of those fluff shows but unless I need a good laugh I'll pass.
Way to many things I see them doing that's just not going to hold up in the real world.
A sledge hammer to remove cabinets, give me a break.
Old 03-06-2013, 11:48 AM   #10
And they use the sledgehammer while wearing flip-flops.
MissKat is offline   Reply With Quote
Old 03-06-2013, 04:35 PM   #11
depends on the cabinets. only once have i had to dig out the sledge to remove cabinets. it was on a extremely high end house where the cabinet builder used 3/4" plywood on the backs of the the boxes then countersunk all the screws and plugged them.. we coiuldnt get at the screws to simply back them out.. we ended up beating them off the walls.
if this were a melamine kitchen i coiuld do the same thing with my bare hands.. shows the difference in quality between high and and low end materials plus the assembly process used
small porch framing details - question wombosi Building & Construction 0 05-04-2011 09:35 PM
Framing Question flati Building & Construction 10 01-12-2010 11:24 AM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 12:17 PM
what type compressor for framing nailer drewhart Tools 4 07-27-2008 02:17 PM
stupid framing question amakarevic Building & Construction 12 02-23-2008 04:29 PM
